[Gdal-dev] Updated MrSID Driver
Andrey Kiselev
dron at ak4719.spb.edu
Wed Feb 11 16:59:56 EST 2004
On Tue, Feb 10, 2004 at 08:31:46AM -0500, Johan A. Goossens wrote:
> Attached are an updated version of the MrSID driver and VC-7 Makefile.
> They have been changed to be compatible with the new 3.2.1 MrSID DSDK.
> I've tested it on a Windows XP platform and successfully used gdalwarp
> on a number of MrSID files.
> You also need to change nmake.opt and configure since the libraries
> are now in ${MRSID_DSDK}/lib (not in $MRSID_ DSDK}/bin/lib).
Johan,
Have you tried the latest driver update? I did changes needed to be
compatible both with new and old API versions.
Andrey
Andrey V. Kiselev
Home phone: +7 812 5274898 ICQ# 26871517
