[Gdal-dev] missing libproj.so
Norman Vine nhv at cape.com
Tue Feb 17 15:06:27 EST 2004
Matt Wilkie wrote:
> Norman Vine wrote:
>  > if it doesn't - holler again
> Holler! Holler!
> > and I haven't tried building with Andrey's changes yet but
> > ./configure --with-static-proj4=yes
> > make
> > should then just work :-)
> with './configure --with-static-proj4=yes' and
> ./configure --without-ogr --with-static-proj4=yes'
> I get errors (attached). (today's daily cvs)
I still haven't tried building the with-static-proj4 flag but ...
inspecting your error messages it appears as if you
are just missing
-L$(PATH_TO_PROJLIB) -lproj
not sure of the best way to add this to the configure files though
so to get 'working' I would just manually insert this into the
CONFIG_LIBS variable in GDALMakeOpt
ie
# CONFIG_LIBS is what local program should link against, and CONFIG_LIBS_INS
# is what will be emitted into the gdal-config script that is installed
# globally.
ifeq ($(HAVE_LIBTOOL), yes)
CONFIG_LIBS = $(LIBGDAL)  -L$(PATH_TO_PROJLIB) -lproj
This will be required for Cygwin and MingW compiles as Win32
doew not allow any unreferenced symbols
HTH
Norman
