[Gdal-dev] missing libproj.so
Matt Wilkie matt.wilkie at gov.yk.ca
Tue Feb 17 13:56:27 EST 2004
Norman Vine wrote:
 > if it doesn't - holler again
Holler! Holler!
> and I haven't tried building with Andrey's changes yet but
> ./configure --with-static-proj4=yes
> make
> should then just work :-)
with './configure --with-static-proj4=yes' and
./configure --without-ogr --with-static-proj4=yes'
I get errors (attached). (today's daily cvs)
What do you get?
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
make[1]: Entering directory `/usr/local/src/gdal-cvs-040217/ogr'
/bin/sh.exe ../libtool --mode=link      g++  ogrinfo.o ../libgdal.la -o ogrinfo.exe
g++ ogrinfo.o -o ogrinfo.exe  ../.libs/libgdal.a -lz
../.libs/libgdal.a(ogrct.o)(.text+0xf0):ogrct.cpp: undefined reference to `_pj_init_plus'
../.libs/libgdal.a(ogrct.o)(.text+0xf5):ogrct.cpp: undefined reference to `_pj_init'
../.libs/libgdal.a(ogrct.o)(.text+0xfa):ogrct.cpp: undefined reference to `_pj_strerrno'
../.libs/libgdal.a(ogrct.o)(.text+0x104):ogrct.cpp: undefined reference to `_pj_fwd'
../.libs/libgdal.a(ogrct.o)(.text+0x10e):ogrct.cpp: undefined reference to `_pj_inv'
../.libs/libgdal.a(ogrct.o)(.text+0x118):ogrct.cpp: undefined reference to `_pj_free'
../.libs/libgdal.a(ogrct.o)(.text+0x122):ogrct.cpp: undefined reference to `_pj_transform'
../.libs/libgdal.a(ogrct.o)(.text+0x12c):ogrct.cpp: undefined reference to `_pj_get_errno_ref'
../.libs/libgdal.a(ogrct.o)(.text+0x136):ogrct.cpp: undefined reference to `_pj_get_def'
../.libs/libgdal.a(ogrct.o)(.text+0x140):ogrct.cpp: undefined reference to `_pj_transform'
../.libs/libgdal.a(ogrct.o)(.text+0x14d):ogrct.cpp: undefined reference to `_pj_dalloc'
../.libs/libgdal.a(ogrct.o)(.text+0x189):ogrct.cpp: undefined reference to `_pj_transform'
collect2: ld returned 1 exit status
make[1]: *** [ogrinfo.exe] Error 1
make[1]: Leaving directory `/usr/local/src/gdal-cvs-040217/ogr'
make: *** [ogr-apps] Error 2
/bin/sh.exe /usr/local/src/gdal-cvs-040217/libtool --mode=link  g++  gdalinfo.o  \
        /usr/local/src/gdal-cvs-040217/libgdal.la -o gdalinfo.exe
g++ gdalinfo.o -o gdalinfo.exe  /usr/local/src/gdal-cvs-040217/.libs/libgdal.a -lz
/usr/local/src/gdal-cvs-040217/.libs/libgdal.a(ogrct.o)(.text+0xf0):ogrct.cpp: undefined reference to `_pj_init_plus'
/usr/local/src/gdal-cvs-040217/.libs/libgdal.a(ogrct.o)(.text+0xf5):ogrct.cpp: undefined reference to `_pj_init'
/usr/local/src/gdal-cvs-040217/.libs/libgdal.a(ogrct.o)(.text+0xfa):ogrct.cpp: undefined reference to `_pj_strerrno'
/usr/local/src/gdal-cvs-040217/.libs/libgdal.a(ogrct.o)(.text+0x104):ogrct.cpp: undefined reference to `_pj_fwd'
/usr/local/src/gdal-cvs-040217/.libs/libgdal.a(ogrct.o)(.text+0x10e):ogrct.cpp: undefined reference to `_pj_inv'
/usr/local/src/gdal-cvs-040217/.libs/libgdal.a(ogrct.o)(.text+0x118):ogrct.cpp: undefined reference to `_pj_free'
/usr/local/src/gdal-cvs-040217/.libs/libgdal.a(ogrct.o)(.text+0x122):ogrct.cpp: undefined reference to `_pj_transform'
/usr/local/src/gdal-cvs-040217/.libs/libgdal.a(ogrct.o)(.text+0x12c):ogrct.cpp: undefined reference to `_pj_get_errno_ref'
/usr/local/src/gdal-cvs-040217/.libs/libgdal.a(ogrct.o)(.text+0x136):ogrct.cpp: undefined reference to `_pj_get_def'
/usr/local/src/gdal-cvs-040217/.libs/libgdal.a(ogrct.o)(.text+0x140):ogrct.cpp: undefined reference to `_pj_transform'
/usr/local/src/gdal-cvs-040217/.libs/libgdal.a(ogrct.o)(.text+0x14d):ogrct.cpp: undefined reference to `_pj_dalloc'
/usr/local/src/gdal-cvs-040217/.libs/libgdal.a(ogrct.o)(.text+0x189):ogrct.cpp: undefined reference to `_pj_transform'
make[1]: *** [gdalinfo.exe] Error 1
make[1]: Leaving directory `/usr/local/src/gdal-cvs-040217/apps'
make: *** [apps-target] Error 2
