[Gdal-dev] Radical OGR Update
Frank Warmerdam
warmerdam at pobox.com
Thu Feb 19 12:10:03 EST 2004
Alessandro Amici wrote:
> if you are going to do a major restucture, even moving file around, a 1.2.0
> branch will look more like a separate project that happen to reside inside
> the same cvs than a real branch (that is, you will not able to merge stuff
> anyhow).
> however waiting 'a few months' untill 1.2.x is stable seems overkill to me.
> since it is a dead-end anyhow, why not forking it at some stage (after the
> 1.2.0 release) and put it into 'critical fixes only'. if it is better to fork
> gdal in a cvs branch or in a copied cvs repository i'll leave to your
> taste ;)
Alessandro,
I hate trying to keep track of what version changes go into when there are
branches other than the "development trunk". I have seen branches cause
untold hassles in projects like GRASS and to a lesser extent in MapServer.
So, once I am ready to start restructuring I may create a 1.2 branch for
fixes to a "stable 1.2" series, but I won't if I can avoid it. Restructuring
would happen in the trunk of course.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
