[Gdal-dev] Radical OGR Update
Gillian Walter gillian.walter at atlantis-scientific.com
Thu Feb 19 14:54:19 EST 2004
I'd like to second the branch motion.   I've had fewer problems with
OpenEV release preparation and maintenance since I started using
branches (I'll be creating a new one off the main trunk fairly soon).
It makes it much easier to create and track patches, and also avoids
unpleasant surprises when you are in the bug-fix stages of a release and
someone else is in development mode.
Gillian
Daniel Morissette wrote:
> Frank Warmerdam wrote:
>> I hate trying to keep track of what version changes go into when
>> there are
>> branches other than the "development trunk".  I have seen branches cause
>> untold hassles in projects like GRASS and to a lesser extent in
>> MapServer.
> I don't think we had that many problems with branches in MapServer?
> There was some confusion on the branch and tag names at some point but I
> think we're doing better since version 3.6 now that we name them
> consistently ("branch-x-y" and "rel-x-y-z"). Using the branches work
> very well and allow us to continue to support stable releases while
> working on major restructuring in the main trunk.  As you know MapServer
> has undergone quite a few major changes in the last 2 years and without
> CVS branches it would have been almost impossible to support the users.
> All this to say: I think a stable branch should be created after the 1.2
> release and before you start the restructuring.  Then *bugfix* releases
> should be done as required using 1.2.x version numbers.
> Also, I would like to suggest that you stop being cheap on version
> numbers ;) ... instead of going with 1.1.x when new features or new
> drivers are added, I think you should go 1.2, 1.3, 1.4 and use the last
> digit of the version numbers only for bug fix releases (after creating a
> stable branch in CVS).  That's how most projects seem to work, that also
> how we do things with MapServer and that works very well.
>> So, once I am ready to start restructuring I may create a 1.2 branch for
>> fixes to a "stable 1.2" series, but I won't if I can avoid it.
>> Restructuring
>> would happen in the trunk of course.
> Great!  But I don't think you can avoid it.  ;)
> My 0.02$
> Daniel
