[Gdal-dev] 1.2.0a Release
Oliver Wesp wesp at gdv.com
Fri Feb 20 04:17:45 EST 2004
Daniel Morissette wrote:
> Trying to build on Solaris 8, using GCC 2.95.2, I get the following errors:
Trying to build on Solaris 8 using GCC 3.3.1 works fine for me. Although
I had to disable libtool using --without-libtool in order to get it
done. But iirc I had to do this for previous releases as well and this
is nothing special with 1.2.0a.
I did a build including oci support (Oracle9i, 32bit client libs). Works
fine as well.
best regards
Oliver
Dipl.-Geogr. Oliver Wesp
Gesellschaft fuer geografische Datenverarbeitung
Binger Strasse 49-51
D-55218 Ingelheim
fon: +49 6132 714818
fax: +49 6132 714828
http: www.gdv.com
