[Gdal-dev] 1.2.0a Release
Alessandro Amici
alexamici at fastwebnet.it
Fri Feb 20 13:20:32 EST 2004
Oliver,
On Friday 20 February 2004 13:33, Oliver Wesp wrote:
> ld: warning: file
> /usr/local/lib/gcc-lib/sparc-sun-solaris2.8/../../libstdc++.so: linked
> to /usr/local/lib/./libstdc++.so: attempted multiple inclusion of file
this looks harmless
> With oci it gives me an error which doesn't seems to me like it has
> anything to do with the problems we had back in october. I attched a
> text file with the last part of the output from the build process.
> false cru .libs/libgdal.a ./frmts/o/EnvisatFile.o [...]
weird! somehow libtool does not find the ar program or it doesn't like what it
finds. is it possible that you don't have the 'ar' directory in your PATH?
(unlikely)
can you see if something like:
$ AR=/path/to/ar ./configure [etc]
solves the problem?
cheers,
alessandro
