[Gdal-dev] 1.2.0a Release
Oliver Wesp wesp at gdv.com
Fri Feb 20 07:33:38 EST 2004
Alessandro Amici wrote:
> Oliver
> On Friday 20 February 2004 10:17, Oliver Wesp wrote:
> does it break without oci support as well?
> is it the same error you reported in october?
Without oci support it seems to work also it gives me a warning right at
the end:
./configure --with-oci=no
g++ gdaltindex.o -o .libs/gdaltindex
/export/home/oliver/tmp/gdal_2/gdal-1.2.0a/.libs/libgdal.so
/usr/local/lib/libjpeg.so -lpng -lz -ldl /usr/local/lib/./libstdc++.so
-L/usr2/SOURCES/S8/gcc-3.3.1/objdir/sparc-sun-solaris2.8/libstdc++-v3/src
-L/usr2/SOURCES/S8/gcc-3.3.1/objdir/sparc-sun-solaris2.8/libstdc++-v3/src/.libs
-L/usr2/SOURCES/S8/gcc-3.3.1/objdir/gcc
-L/usr/local/sparc-sun-solaris2.8/bin
-L/usr/local/sparc-sun-solaris2.8/lib
-L/usr/local/lib/gcc-lib/sparc-sun-solaris2.8/../../../sparc-sun-solaris2.8/lib
-L/usr/local/lib/gcc-lib/sparc-sun-solaris2.8/../.. -Wl,-R
-Wl,/usr/local/lib -Wl,-R -Wl,/usr/local/lib/.
ld: warning: file
/usr/local/lib/gcc-lib/sparc-sun-solaris2.8/../../libstdc++.so: linked
to /usr/local/lib/./libstdc++.so: attempted multiple inclusion of file
creating gdaltindex
make[1]: Leaving directory `/export/home/oliver/tmp/gdal_2/gdal-1.2.0a/apps'
With oci it gives me an error which doesn't seems to me like it has
anything to do with the problems we had back in october. I attched a
text file with the last part of the output from the build process.
best regards
Oliver
Dipl.-Geogr. Oliver Wesp
Gesellschaft fuer geografische Datenverarbeitung
Binger Strasse 49-51
D-55218 Ingelheim
fon: +49 6132 714818
fax: +49 6132 714828
http: www.gdv.com
g++ -shared -nostdlib  /usr/local/lib/gcc-lib/sparc-sun-solaris2.8/3.3.1/crti.o /usr/ccs/lib/values-Xa.o /usr/local/lib/gcc-lib/sparc-sun-solaris2.8/3.3.1/crtbegin.o  ./frmts/o/.libs/EnvisatFile.o ./frmts/o/.libs/aaigriddataset.o ./frmts/o/.libs/aigccitt.o ./frmts/o/.libs/aigdataset.o ./frmts/o/.libs/aigopen.o ./frmts/o/.libs/atlsci_spheroid.o ./frmts/o/.libs/bmpdataset.o ./frmts/o/.libs/bsb_read.o ./frmts/o/.libs/bsbdataset.o ./frmts/o/.libs/btdataset.o ./frmts/o/.libs/ceos.o ./frmts/o/.libs/ceosdataset.o ./frmts/o/.libs/ceosopen.o ./frmts/o/.libs/ceosrecipe.o ./frmts/o/.libs/ceossar.o ./frmts/o/.libs/ddffield.o ./frmts/o/.libs/ddffielddefn.o ./frmts/o/.libs/ddfmodule.o ./frmts/o/.libs/ddfrecord.o ./frmts/o/.libs/ddfsubfielddefn.o ./frmts/o/.libs/ddfutils.o ./frmts/o/.libs/dgif_lib.o ./frmts/o/.libs/doq1dataset.o ./frmts/o/.libs/doq2dataset.o ./frmts/o/.libs/dted_api.o ./frmts/o/.libs/dted_create.o ./frmts/o/.libs/dted_ptstream.o ./frmts/o/.libs/dteddataset.o ./frmts/o/.libs/egif_lib.o ./frmts/o/.libs/ehdrdataset.o ./frmts/o/.libs/elasdataset.o ./frmts/o/.libs/envidataset.o ./frmts/o/.libs/envisatdataset.o ./frmts/o/.libs/fastdataset.o ./frmts/o/.libs/fit.o ./frmts/o/.libs/fitdataset.o ./frmts/o/.libs/fujibasdataset.o ./frmts/o/.libs/gdalallregister.o ./frmts/o/.libs/geo_extra.o ./frmts/o/.libs/geo_free.o ./frmts/o/.libs/geo_get.o ./frmts/o/.libs/geo_names.o ./frmts/o/.libs/geo_new.o ./frmts/o/.libs/geo_normalize.o ./frmts/o/.libs/geo_print.o ./frmts/o/.libs/geo_set.o ./frmts/o/.libs/geo_tiffp.o ./frmts/o/.libs/geo_trans.o ./frmts/o/.libs/geo_write.o ./frmts/o/.libs/geotiff.o ./frmts/o/.libs/geotiff_proj4.o ./frmts/o/.libs/gif_err.o ./frmts/o/.libs/gifalloc.o ./frmts/o/.libs/gifdataset.o ./frmts/o/.libs/giodataset.o ./frmts/o/.libs/gridlib.o ./frmts/o/.libs/gscdataset.o ./frmts/o/.libs/gt_overview.o ./frmts/o/.libs/gt_wkt_srs.o ./frmts/o/.libs/gxf_ogcwkt.o ./frmts/o/.libs/gxf_proj4.o ./frmts/o/.libs/gxfdataset.o ./frmts/o/.libs/gxfopen.o ./frmts/o/.libs/hfaband.o ./frmts/o/.libs/hfadataset.o ./frmts/o/.libs/hfadictionary.o ./frmts/o/.libs/hfaentry.o ./frmts/o/.libs/hfafield.o ./frmts/o/.libs/hfaopen.o ./frmts/o/.libs/hfatype.o ./frmts/o/.libs/hkvdataset.o ./frmts/o/.libs/jdemdataset.o ./frmts/o/.libs/jpgdataset.o ./frmts/o/.libs/l1bdataset.o ./frmts/o/.libs/link.o ./frmts/o/.libs/memdataset.o ./frmts/o/.libs/mffdataset.o ./frmts/o/.libs/mgrs.o ./frmts/o/.libs/nitfdataset.o ./frmts/o/.libs/nitffile.o ./frmts/o/.libs/nitfimage.o ./frmts/o/.libs/pauxdataset.o ./frmts/o/.libs/pcidskdataset.o ./frmts/o/.libs/pngdataset.o ./frmts/o/.libs/pnmdataset.o ./frmts/o/.libs/rawdataset.o ./frmts/o/.libs/sar_ceosdataset.o ./frmts/o/.libs/sdtsattrreader.o ./frmts/o/.libs/sdtscatd.o ./frmts/o/.libs/sdtsdataset.o ./frmts/o/.libs/sdtsindexedreader.o ./frmts/o/.libs/sdtsiref.o ./frmts/o/.libs/sdtslib.o ./frmts/o/.libs/sdtslinereader.o ./frmts/o/.libs/sdtspointreader.o ./frmts/o/.libs/sdtspolygonreader.o ./frmts/o/.libs/sdtsrasterreader.o ./frmts/o/.libs/sdtstransfer.o ./frmts/o/.libs/sdtsxref.o ./frmts/o/.libs/tif_aux.o ./frmts/o/.libs/tif_close.o ./frmts/o/.libs/tif_codec.o ./frmts/o/.libs/tif_color.o ./frmts/o/.libs/tif_compress.o ./frmts/o/.libs/tif_dir.o ./frmts/o/.libs/tif_dirinfo.o ./frmts/o/.libs/tif_dirread.o ./frmts/o/.libs/tif_dirwrite.o ./frmts/o/.libs/tif_dumpmode.o ./frmts/o/.libs/tif_error.o ./frmts/o/.libs/tif_extension.o ./frmts/o/.libs/tif_fax3.o ./frmts/o/.libs/tif_fax3sm.o ./frmts/o/.libs/tif_flush.o ./frmts/o/.libs/tif_getimage.o ./frmts/o/.libs/tif_jpeg.o ./frmts/o/.libs/tif_luv.o ./frmts/o/.libs/tif_lzw.o ./frmts/o/.libs/tif_memio.o ./frmts/o/.libs/tif_next.o ./frmts/o/.libs/tif_open.o ./frmts/o/.libs/tif_overview.o ./frmts/o/.libs/tif_ovrcache.o ./frmts/o/.libs/tif_packbits.o ./frmts/o/.libs/tif_pixarlog.o ./frmts/o/.libs/tif_predict.o ./frmts/o/.libs/tif_print.o ./frmts/o/.libs/tif_read.o ./frmts/o/.libs/tif_strip.o ./frmts/o/.libs/tif_swab.o ./frmts/o/.libs/tif_thunder.o ./frmts/o/.libs/tif_tile.o ./frmts/o/.libs/tif_version.o ./frmts/o/.libs/tif_vsi.o ./frmts/o/.libs/tif_warning.o ./frmts/o/.libs/tif_write.o ./frmts/o/.libs/tif_zip.o ./frmts/o/.libs/usgsdemdataset.o ./frmts/o/.libs/vrtdataset.o ./frmts/o/.libs/vrtdriver.o ./frmts/o/.libs/vrtfilters.o ./frmts/o/.libs/vrtrasterband.o ./frmts/o/.libs/vrtsources.o ./frmts/o/.libs/xpmdataset.o ./frmts/o/.libs/xtiff.o ./gcore/.libs/gdal_misc.o ./gcore/.libs/gdalcolortable.o ./gcore/.libs/gdaldataset.o ./gcore/.libs/gdaldefaultoverviews.o ./gcore/.libs/gdaldriver.o ./gcore/.libs/gdaldrivermanager.o ./gcore/.libs/gdalmajorobject.o ./gcore/.libs/gdalopen.o ./gcore/.libs/gdalrasterband.o ./gcore/.libs/gdalrasterblock.o ./gcore/.libs/overview.o ./gcore/.libs/rasterio.o ./port/.libs/cpl_conv.o ./port/.libs/cpl_csv.o ./port/.libs/cpl_dir.o ./port/.libs/cpl_error.o ./port/.libs/cpl_findfile.o ./port/.libs/cpl_list.o ./port/.libs/cpl_minixml.o ./port/.libs/cpl_multiproc.o ./port/.libs/cpl_path.o ./port/.libs/cpl_string.o ./port/.libs/cpl_vsil_unix_stdio_64.o ./port/.libs/cpl_vsisimple.o ./port/.libs/cplgetsymbol.o ./alg/.libs/contour.o ./alg/.libs/gdal_crs.o ./alg/.libs/gdal_rpc.o ./alg/.libs/gdalchecksum.o ./alg/.libs/gdaldither.o ./alg/.libs/gdalmediancut.o ./alg/.libs/gdalsimplewarp.o ./alg/.libs/gdaltransformer.o ./alg/.libs/gdalwarper.o ./alg/.libs/gdalwarpkernel.o ./alg/.libs/gdalwarpoperation.o ./ogr/ogrsf_frmts/o/.libs/avc_bin.o ./ogr/ogrsf_frmts/o/.libs/avc_binwr.o ./ogr/ogrsf_frmts/o/.libs/avc_e00gen.o ./ogr/ogrsf_frmts/o/.libs/avc_e00parse.o ./ogr/ogrsf_frmts/o/.libs/avc_e00read.o ./ogr/ogrsf_frmts/o/.libs/avc_e00write.o ./ogr/ogrsf_frmts/o/.libs/avc_mbyte.o ./ogr/ogrsf_frmts/o/.libs/avc_misc.o ./ogr/ogrsf_frmts/o/.libs/avc_rawbin.o ./ogr/ogrsf_frmts/o/.libs/dbfopen.o ./ogr/ogrsf_frmts/o/.libs/ddfrecordindex.o ./ogr/ogrsf_frmts/o/.libs/dgnfloat.o ./ogr/ogrsf_frmts/o/.libs/dgnhelp.o ./ogr/ogrsf_frmts/o/.libs/dgnopen.o ./ogr/ogrsf_frmts/o/.libs/dgnread.o ./ogr/ogrsf_frmts/o/.libs/dgnstroke.o ./ogr/ogrsf_frmts/o/.libs/dgnwrite.o ./ogr/ogrsf_frmts/o/.libs/gmlfeature.o ./ogr/ogrsf_frmts/o/.libs/gmlfeatureclass.o ./ogr/ogrsf_frmts/o/.libs/gmlpropertydefn.o ./ogr/ogrsf_frmts/o/.libs/gmlreader.o ./ogr/ogrsf_frmts/o/.libs/ll_recio.o ./ogr/ogrsf_frmts/o/.libs/mitab_bounds.o ./ogr/ogrsf_frmts/o/.libs/mitab_coordsys.o ./ogr/ogrsf_frmts/o/.libs/mitab_datfile.o ./ogr/ogrsf_frmts/o/.libs/mitab_feature.o ./ogr/ogrsf_frmts/o/.libs/mitab_feature_mif.o ./ogr/ogrsf_frmts/o/.libs/mitab_geometry.o ./ogr/ogrsf_frmts/o/.libs/mitab_idfile.o ./ogr/ogrsf_frmts/o/.libs/mitab_imapinfofile.o ./ogr/ogrsf_frmts/o/.libs/mitab_indfile.o ./ogr/ogrsf_frmts/o/.libs/mitab_mapcoordblock.o ./ogr/ogrsf_frmts/o/.libs/mitab_mapfile.o ./ogr/ogrsf_frmts/o/.libs/mitab_mapheaderblock.o ./ogr/ogrsf_frmts/o/.libs/mitab_mapindexblock.o ./ogr/ogrsf_frmts/o/.libs/mitab_mapobjectblock.o ./ogr/ogrsf_frmts/o/.libs/mitab_maptoolblock.o ./ogr/ogrsf_frmts/o/.libs/mitab_middatafile.o ./ogr/ogrsf_frmts/o/.libs/mitab_miffile.o ./ogr/ogrsf_frmts/o/.libs/mitab_ogr_datasource.o ./ogr/ogrsf_frmts/o/.libs/mitab_ogr_driver.o ./ogr/ogrsf_frmts/o/.libs/mitab_rawbinblock.o ./ogr/ogrsf_frmts/o/.libs/mitab_spatialref.o ./ogr/ogrsf_frmts/o/.libs/mitab_tabfile.o ./ogr/ogrsf_frmts/o/.libs/mitab_tabseamless.o ./ogr/ogrsf_frmts/o/.libs/mitab_tabview.o ./ogr/ogrsf_frmts/o/.libs/mitab_tooldef.o ./ogr/ogrsf_frmts/o/.libs/mitab_utils.o ./ogr/ogrsf_frmts/o/.libs/ntf_codelist.o ./ogr/ogrsf_frmts/o/.libs/ntf_estlayers.o ./ogr/ogrsf_frmts/o/.libs/ntf_generic.o ./ogr/ogrsf_frmts/o/.libs/ntf_raster.o ./ogr/ogrsf_frmts/o/.libs/ntffilereader.o ./ogr/ogrsf_frmts/o/.libs/ntfrecord.o ./ogr/ogrsf_frmts/o/.libs/ntfstroke.o ./ogr/ogrsf_frmts/o/.libs/oci_utils.o ./ogr/ogrsf_frmts/o/.libs/ogr_attrind.o ./ogr/ogrsf_frmts/o/.libs/ogr_gensql.o ./ogr/ogrsf_frmts/o/.libs/ogr_miattrind.o ./ogr/ogrsf_frmts/o/.libs/ogravcbindatasource.o ./ogr/ogrsf_frmts/o/.libs/ogravcbindriver.o ./ogr/ogrsf_frmts/o/.libs/ogravcbinlayer.o ./ogr/ogrsf_frmts/o/.libs/ogravcdatasource.o ./ogr/ogrsf_frmts/o/.libs/ogravclayer.o ./ogr/ogrsf_frmts/o/.libs/ogrdatasource.o ./ogr/ogrsf_frmts/o/.libs/ogrdgndatasource.o ./ogr/ogrsf_frmts/o/.libs/ogrdgndriver.o ./ogr/ogrsf_frmts/o/.libs/ogrdgnlayer.o ./ogr/ogrsf_frmts/o/.libs/ogrgmldatasource.o ./ogr/ogrsf_frmts/o/.libs/ogrgmldriver.o ./ogr/ogrsf_frmts/o/.libs/ogrgmllayer.o ./ogr/ogrsf_frmts/o/.libs/ogrlayer.o ./ogr/ogrsf_frmts/o/.libs/ogrmemdatasource.o ./ogr/ogrsf_frmts/o/.libs/ogrmemdriver.o ./ogr/ogrsf_frmts/o/.libs/ogrmemlayer.o ./ogr/ogrsf_frmts/o/.libs/ogrntfdatasource.o ./ogr/ogrsf_frmts/o/.libs/ogrntfdriver.o ./ogr/ogrsf_frmts/o/.libs/ogrntffeatureclasslayer.o ./ogr/ogrsf_frmts/o/.libs/ogrntflayer.o ./ogr/ogrsf_frmts/o/.libs/ogrocidatasource.o ./ogr/ogrsf_frmts/o/.libs/ogrocidriver.o ./ogr/ogrsf_frmts/o/.libs/ogrocilayer.o ./ogr/ogrsf_frmts/o/.libs/ogrociloaderlayer.o ./ogr/ogrsf_frmts/o/.libs/ogrociselectlayer.o ./ogr/ogrsf_frmts/o/.libs/ogrocisession.o ./ogr/ogrsf_frmts/o/.libs/ogrocistatement.o ./ogr/ogrsf_frmts/o/.libs/ogrocistringbuf.o ./ogr/ogrsf_frmts/o/.libs/ogrocitablelayer.o ./ogr/ogrsf_frmts/o/.libs/ogrociwritablelayer.o ./ogr/ogrsf_frmts/o/.libs/ogrrecdatasource.o ./ogr/ogrsf_frmts/o/.libs/ogrrecdriver.o ./ogr/ogrsf_frmts/o/.libs/ogrreclayer.o ./ogr/ogrsf_frmts/o/.libs/ogrregisterall.o ./ogr/ogrsf_frmts/o/.libs/ogrs57datasource.o ./ogr/ogrsf_frmts/o/.libs/ogrs57driver.o ./ogr/ogrsf_frmts/o/.libs/ogrs57layer.o ./ogr/ogrsf_frmts/o/.libs/ogrsdtsdatasource.o ./ogr/ogrsf_frmts/o/.libs/ogrsdtsdriver.o ./ogr/ogrsf_frmts/o/.libs/ogrsdtslayer.o ./ogr/ogrsf_frmts/o/.libs/ogrsfdriver.o ./ogr/ogrsf_frmts/o/.libs/ogrsfdriverregistrar.o ./ogr/ogrsf_frmts/o/.libs/ogrshapedatasource.o ./ogr/ogrsf_frmts/o/.libs/ogrshapedriver.o ./ogr/ogrsf_frmts/o/.libs/ogrshapelayer.o ./ogr/ogrsf_frmts/o/.libs/ogrtigerdatasource.o ./ogr/ogrsf_frmts/o/.libs/ogrtigerdriver.o ./ogr/ogrsf_frmts/o/.libs/ogrtigerlayer.o ./ogr/ogrsf_frmts/o/.libs/ogrvrtdatasource.o ./ogr/ogrsf_frmts/o/.libs/ogrvrtdriver.o ./ogr/ogrsf_frmts/o/.libs/ogrvrtlayer.o ./ogr/ogrsf_frmts/o/.libs/s57classregistrar.o ./ogr/ogrsf_frmts/o/.libs/s57featuredefns.o ./ogr/ogrsf_frmts/o/.libs/s57filecollector.o ./ogr/ogrsf_frmts/o/.libs/s57reader.o ./ogr/ogrsf_frmts/o/.libs/s57writer.o ./ogr/ogrsf_frmts/o/.libs/shape2ogr.o ./ogr/ogrsf_frmts/o/.libs/shpopen.o ./ogr/ogrsf_frmts/o/.libs/shptree.o ./ogr/ogrsf_frmts/o/.libs/tigeraltname.o ./ogr/ogrsf_frmts/o/.libs/tigerarealandmarks.o ./ogr/ogrsf_frmts/o/.libs/tigercompletechain.o ./ogr/ogrsf_frmts/o/.libs/tigerentitynames.o ./ogr/ogrsf_frmts/o/.libs/tigerfeatureids.o ./ogr/ogrsf_frmts/o/.libs/tigerfilebase.o ./ogr/ogrsf_frmts/o/.libs/tigeridhistory.o ./ogr/ogrsf_frmts/o/.libs/tigerkeyfeatures.o ./ogr/ogrsf_frmts/o/.libs/tigerlandmarks.o ./ogr/ogrsf_frmts/o/.libs/tigeroverunder.o ./ogr/ogrsf_frmts/o/.libs/tigerpip.o ./ogr/ogrsf_frmts/o/.libs/tigerpoint.o ./ogr/ogrsf_frmts/o/.libs/tigerpolychainlink.o ./ogr/ogrsf_frmts/o/.libs/tigerpolygon.o ./ogr/ogrsf_frmts/o/.libs/tigerpolygoncorrections.o ./ogr/ogrsf_frmts/o/.libs/tigerpolygoneconomic.o ./ogr/ogrsf_frmts/o/.libs/tigertlidrange.o ./ogr/ogrsf_frmts/o/.libs/tigerzerocellid.o ./ogr/ogrsf_frmts/o/.libs/tigerzipcodes.o ./ogr/ogrsf_frmts/o/.libs/tigerzipplus4.o ./ogr/.libs/ogrgeometryfactory.o ./ogr/.libs/ogrpoint.o ./ogr/.libs/ogrcurve.o ./ogr/.libs/ogrlinestring.o ./ogr/.libs/ogrlinearring.o ./ogr/.libs/ogrpolygon.o ./ogr/.libs/ogrutils.o ./ogr/.libs/ogrgeometry.o ./ogr/.libs/ogrgeometrycollection.o ./ogr/.libs/ogrmultipolygon.o ./ogr/.libs/ogrsurface.o ./ogr/.libs/ogrmultipoint.o ./ogr/.libs/ogrmultilinestring.o ./ogr/.libs/ogr_api.o ./ogr/.libs/ogrfeature.o ./ogr/.libs/ogrfeaturedefn.o ./ogr/.libs/ogrfeaturequery.o ./ogr/.libs/ogrfeaturestyle.o ./ogr/.libs/ogrfielddefn.o ./ogr/.libs/ogrspatialreference.o ./ogr/.libs/ogr_srsnode.o ./ogr/.libs/ogr_srs_proj4.o ./ogr/.libs/ogr_fromepsg.o ./ogr/.libs/ogrct.o ./ogr/.libs/ogr_opt.o ./ogr/.libs/ogr_srs_esri.o ./ogr/.libs/ogr_srs_pci.o ./ogr/.libs/ogr_srs_usgs.o ./ogr/.libs/swq.o ./ogr/.libs/ogr_srs_validate.o ./ogr/.libs/ogr_srs_xml.o ./ogr/.libs/ograssemblepolygon.o ./ogr/.libs/ogr2gmlgeometry.o ./ogr/.libs/gml2ogrgeometry.o  -Wl,-R -Wl,/usr/local/lib -Wl,-R -Wl,/usr/local/lib/. -Wl,-R -Wl,/usr/local/lib -Wl,-R -Wl,/usr/local/lib/. -L/usr/local/lib/gcc-lib/sparc-sun-solaris2.8/../.. -L/usr/local/lib/gcc-lib/sparc-sun-solaris2.8/../../../sparc-sun-solaris2.8/lib -L/usr/local/sparc-sun-solaris2.8/lib -L/usr/local/sparc-sun-solaris2.8/bin -L/usr2/SOURCES/S8/gcc-3.3.1/objdir/gcc -L/usr2/SOURCES/S8/gcc-3.3.1/objdir/sparc-sun-solaris2.8/libstdc++-v3/src/.libs -L/usr2/SOURCES/S8/gcc-3.3.1/objdir/sparc-sun-solaris2.8/libstdc++-v3/src -lclntsh -L/export/home/oracle/OraHome2/lib /usr/local/lib/libjpeg.so -lpng -lz -ldl -L/usr/local/lib/gcc-lib/sparc-sun-solaris2.8/3.3.1 -L/usr/ccs/bin -L/usr/ccs/lib -L/usr/local/lib/gcc-lib/sparc-sun-solaris2.8/3.3.1/../../.. /usr/local/lib/./libstdc++.so -lm -lgcc_s /usr/local/lib/gcc-lib/sparc-sun-solaris2.8/3.3.1/crtend.o /usr/local/lib/gcc-lib/sparc-sun-solaris2.8/3.3.1/crtn.o  -Wl,-h -Wl,libgdal.so.1 -o .libs/libgdal.so.1.2.0
(cd .libs && rm -f libgdal.so.1 && ln -s libgdal.so.1.2.0 libgdal.so.1)
(cd .libs && rm -f libgdal.so && ln -s libgdal.so.1.2.0 libgdal.so)
false cru .libs/libgdal.a  ./frmts/o/EnvisatFile.o ./frmts/o/aaigriddataset.o ./frmts/o/aigccitt.o ./frmts/o/aigdataset.o ./frmts/o/aigopen.o ./frmts/o/atlsci_spheroid.o ./frmts/o/bmpdataset.o ./frmts/o/bsb_read.o ./frmts/o/bsbdataset.o ./frmts/o/btdataset.o ./frmts/o/ceos.o ./frmts/o/ceosdataset.o ./frmts/o/ceosopen.o ./frmts/o/ceosrecipe.o ./frmts/o/ceossar.o ./frmts/o/ddffield.o ./frmts/o/ddffielddefn.o ./frmts/o/ddfmodule.o ./frmts/o/ddfrecord.o ./frmts/o/ddfsubfielddefn.o ./frmts/o/ddfutils.o ./frmts/o/dgif_lib.o ./frmts/o/doq1dataset.o ./frmts/o/doq2dataset.o ./frmts/o/dted_api.o ./frmts/o/dted_create.o ./frmts/o/dted_ptstream.o ./frmts/o/dteddataset.o ./frmts/o/egif_lib.o ./frmts/o/ehdrdataset.o ./frmts/o/elasdataset.o ./frmts/o/envidataset.o ./frmts/o/envisatdataset.o ./frmts/o/fastdataset.o ./frmts/o/fit.o ./frmts/o/fitdataset.o ./frmts/o/fujibasdataset.o ./frmts/o/gdalallregister.o ./frmts/o/geo_extra.o ./frmts/o/geo_free.o ./frmts/o/geo_get.o ./frmts/o/geo_names.o ./frmts/o/geo_new.o ./frmts/o/geo_normalize.o ./frmts/o/geo_print.o ./frmts/o/geo_set.o ./frmts/o/geo_tiffp.o ./frmts/o/geo_trans.o ./frmts/o/geo_write.o ./frmts/o/geotiff.o ./frmts/o/geotiff_proj4.o ./frmts/o/gif_err.o ./frmts/o/gifalloc.o ./frmts/o/gifdataset.o ./frmts/o/giodataset.o ./frmts/o/gridlib.o ./frmts/o/gscdataset.o ./frmts/o/gt_overview.o ./frmts/o/gt_wkt_srs.o ./frmts/o/gxf_ogcwkt.o ./frmts/o/gxf_proj4.o ./frmts/o/gxfdataset.o ./frmts/o/gxfopen.o ./frmts/o/hfaband.o ./frmts/o/hfadataset.o ./frmts/o/hfadictionary.o ./frmts/o/hfaentry.o ./frmts/o/hfafield.o ./frmts/o/hfaopen.o ./frmts/o/hfatype.o ./frmts/o/hkvdataset.o ./frmts/o/jdemdataset.o ./frmts/o/jpgdataset.o ./frmts/o/l1bdataset.o ./frmts/o/link.o ./frmts/o/memdataset.o ./frmts/o/mffdataset.o ./frmts/o/mgrs.o ./frmts/o/nitfdataset.o ./frmts/o/nitffile.o ./frmts/o/nitfimage.o ./frmts/o/pauxdataset.o ./frmts/o/pcidskdataset.o ./frmts/o/pngdataset.o ./frmts/o/pnmdataset.o ./frmts/o/rawdataset.o ./frmts/o/sar_ceosdataset.o ./frmts/o/sdtsattrreader.o ./frmts/o/sdtscatd.o ./frmts/o/sdtsdataset.o ./frmts/o/sdtsindexedreader.o ./frmts/o/sdtsiref.o ./frmts/o/sdtslib.o ./frmts/o/sdtslinereader.o ./frmts/o/sdtspointreader.o ./frmts/o/sdtspolygonreader.o ./frmts/o/sdtsrasterreader.o ./frmts/o/sdtstransfer.o ./frmts/o/sdtsxref.o ./frmts/o/tif_aux.o ./frmts/o/tif_close.o ./frmts/o/tif_codec.o ./frmts/o/tif_color.o ./frmts/o/tif_compress.o ./frmts/o/tif_dir.o ./frmts/o/tif_dirinfo.o ./frmts/o/tif_dirread.o ./frmts/o/tif_dirwrite.o ./frmts/o/tif_dumpmode.o ./frmts/o/tif_error.o ./frmts/o/tif_extension.o ./frmts/o/tif_fax3.o ./frmts/o/tif_fax3sm.o ./frmts/o/tif_flush.o ./frmts/o/tif_getimage.o ./frmts/o/tif_jpeg.o ./frmts/o/tif_luv.o ./frmts/o/tif_lzw.o ./frmts/o/tif_memio.o ./frmts/o/tif_next.o ./frmts/o/tif_open.o ./frmts/o/tif_overview.o ./frmts/o/tif_ovrcache.o ./frmts/o/tif_packbits.o ./frmts/o/tif_pixarlog.o ./frmts/o/tif_predict.o ./frmts/o/tif_print.o ./frmts/o/tif_read.o ./frmts/o/tif_strip.o ./frmts/o/tif_swab.o ./frmts/o/tif_thunder.o ./frmts/o/tif_tile.o ./frmts/o/tif_version.o ./frmts/o/tif_vsi.o ./frmts/o/tif_warning.o ./frmts/o/tif_write.o ./frmts/o/tif_zip.o ./frmts/o/usgsdemdataset.o ./frmts/o/vrtdataset.o ./frmts/o/vrtdriver.o ./frmts/o/vrtfilters.o ./frmts/o/vrtrasterband.o ./frmts/o/vrtsources.o ./frmts/o/xpmdataset.o ./frmts/o/xtiff.o ./gcore/gdal_misc.o ./gcore/gdalcolortable.o ./gcore/gdaldataset.o ./gcore/gdaldefaultoverviews.o ./gcore/gdaldriver.o ./gcore/gdaldrivermanager.o ./gcore/gdalmajorobject.o ./gcore/gdalopen.o ./gcore/gdalrasterband.o ./gcore/gdalrasterblock.o ./gcore/overview.o ./gcore/rasterio.o ./port/cpl_conv.o ./port/cpl_csv.o ./port/cpl_dir.o ./port/cpl_error.o ./port/cpl_findfile.o ./port/cpl_list.o ./port/cpl_minixml.o ./port/cpl_multiproc.o ./port/cpl_path.o ./port/cpl_string.o ./port/cpl_vsil_unix_stdio_64.o ./port/cpl_vsisimple.o ./port/cplgetsymbol.o ./alg/contour.o ./alg/gdal_crs.o ./alg/gdal_rpc.o ./alg/gdalchecksum.o ./alg/gdaldither.o ./alg/gdalmediancut.o ./alg/gdalsimplewarp.o ./alg/gdaltransformer.o ./alg/gdalwarper.o ./alg/gdalwarpkernel.o ./alg/gdalwarpoperation.o ./ogr/ogrsf_frmts/o/avc_bin.o ./ogr/ogrsf_frmts/o/avc_binwr.o ./ogr/ogrsf_frmts/o/avc_e00gen.o ./ogr/ogrsf_frmts/o/avc_e00parse.o ./ogr/ogrsf_frmts/o/avc_e00read.o ./ogr/ogrsf_frmts/o/avc_e00write.o ./ogr/ogrsf_frmts/o/avc_mbyte.o ./ogr/ogrsf_frmts/o/avc_misc.o ./ogr/ogrsf_frmts/o/avc_rawbin.o ./ogr/ogrsf_frmts/o/dbfopen.o ./ogr/ogrsf_frmts/o/ddfrecordindex.o ./ogr/ogrsf_frmts/o/dgnfloat.o ./ogr/ogrsf_frmts/o/dgnhelp.o ./ogr/ogrsf_frmts/o/dgnopen.o ./ogr/ogrsf_frmts/o/dgnread.o ./ogr/ogrsf_frmts/o/dgnstroke.o ./ogr/ogrsf_frmts/o/dgnwrite.o ./ogr/ogrsf_frmts/o/gmlfeature.o ./ogr/ogrsf_frmts/o/gmlfeatureclass.o ./ogr/ogrsf_frmts/o/gmlpropertydefn.o ./ogr/ogrsf_frmts/o/gmlreader.o ./ogr/ogrsf_frmts/o/ll_recio.o ./ogr/ogrsf_frmts/o/mitab_bounds.o ./ogr/ogrsf_frmts/o/mitab_coordsys.o ./ogr/ogrsf_frmts/o/mitab_datfile.o ./ogr/ogrsf_frmts/o/mitab_feature.o ./ogr/ogrsf_frmts/o/mitab_feature_mif.o ./ogr/ogrsf_frmts/o/mitab_geometry.o ./ogr/ogrsf_frmts/o/mitab_idfile.o ./ogr/ogrsf_frmts/o/mitab_imapinfofile.o ./ogr/ogrsf_frmts/o/mitab_indfile.o ./ogr/ogrsf_frmts/o/mitab_mapcoordblock.o ./ogr/ogrsf_frmts/o/mitab_mapfile.o ./ogr/ogrsf_frmts/o/mitab_mapheaderblock.o ./ogr/ogrsf_frmts/o/mitab_mapindexblock.o ./ogr/ogrsf_frmts/o/mitab_mapobjectblock.o ./ogr/ogrsf_frmts/o/mitab_maptoolblock.o ./ogr/ogrsf_frmts/o/mitab_middatafile.o ./ogr/ogrsf_frmts/o/mitab_miffile.o ./ogr/ogrsf_frmts/o/mitab_ogr_datasource.o ./ogr/ogrsf_frmts/o/mitab_ogr_driver.o ./ogr/ogrsf_frmts/o/mitab_rawbinblock.o ./ogr/ogrsf_frmts/o/mitab_spatialref.o ./ogr/ogrsf_frmts/o/mitab_tabfile.o ./ogr/ogrsf_frmts/o/mitab_tabseamless.o ./ogr/ogrsf_frmts/o/mitab_tabview.o ./ogr/ogrsf_frmts/o/mitab_tooldef.o ./ogr/ogrsf_frmts/o/mitab_utils.o ./ogr/ogrsf_frmts/o/ntf_codelist.o ./ogr/ogrsf_frmts/o/ntf_estlayers.o ./ogr/ogrsf_frmts/o/ntf_generic.o ./ogr/ogrsf_frmts/o/ntf_raster.o ./ogr/ogrsf_frmts/o/ntffilereader.o ./ogr/ogrsf_frmts/o/ntfrecord.o ./ogr/ogrsf_frmts/o/ntfstroke.o ./ogr/ogrsf_frmts/o/oci_utils.o ./ogr/ogrsf_frmts/o/ogr_attrind.o ./ogr/ogrsf_frmts/o/ogr_gensql.o ./ogr/ogrsf_frmts/o/ogr_miattrind.o ./ogr/ogrsf_frmts/o/ogravcbindatasource.o ./ogr/ogrsf_frmts/o/ogravcbindriver.o ./ogr/ogrsf_frmts/o/ogravcbinlayer.o ./ogr/ogrsf_frmts/o/ogravcdatasource.o ./ogr/ogrsf_frmts/o/ogravclayer.o ./ogr/ogrsf_frmts/o/ogrdatasource.o ./ogr/ogrsf_frmts/o/ogrdgndatasource.o ./ogr/ogrsf_frmts/o/ogrdgndriver.o ./ogr/ogrsf_frmts/o/ogrdgnlayer.o ./ogr/ogrsf_frmts/o/ogrgmldatasource.o ./ogr/ogrsf_frmts/o/ogrgmldriver.o ./ogr/ogrsf_frmts/o/ogrgmllayer.o ./ogr/ogrsf_frmts/o/ogrlayer.o ./ogr/ogrsf_frmts/o/ogrmemdatasource.o ./ogr/ogrsf_frmts/o/ogrmemdriver.o ./ogr/ogrsf_frmts/o/ogrmemlayer.o ./ogr/ogrsf_frmts/o/ogrntfdatasource.o ./ogr/ogrsf_frmts/o/ogrntfdriver.o ./ogr/ogrsf_frmts/o/ogrntffeatureclasslayer.o ./ogr/ogrsf_frmts/o/ogrntflayer.o ./ogr/ogrsf_frmts/o/ogrocidatasource.o ./ogr/ogrsf_frmts/o/ogrocidriver.o ./ogr/ogrsf_frmts/o/ogrocilayer.o ./ogr/ogrsf_frmts/o/ogrociloaderlayer.o ./ogr/ogrsf_frmts/o/ogrociselectlayer.o ./ogr/ogrsf_frmts/o/ogrocisession.o ./ogr/ogrsf_frmts/o/ogrocistatement.o ./ogr/ogrsf_frmts/o/ogrocistringbuf.o ./ogr/ogrsf_frmts/o/ogrocitablelayer.o ./ogr/ogrsf_frmts/o/ogrociwritablelayer.o ./ogr/ogrsf_frmts/o/ogrrecdatasource.o ./ogr/ogrsf_frmts/o/ogrrecdriver.o ./ogr/ogrsf_frmts/o/ogrreclayer.o ./ogr/ogrsf_frmts/o/ogrregisterall.o ./ogr/ogrsf_frmts/o/ogrs57datasource.o ./ogr/ogrsf_frmts/o/ogrs57driver.o ./ogr/ogrsf_frmts/o/ogrs57layer.o ./ogr/ogrsf_frmts/o/ogrsdtsdatasource.o ./ogr/ogrsf_frmts/o/ogrsdtsdriver.o ./ogr/ogrsf_frmts/o/ogrsdtslayer.o ./ogr/ogrsf_frmts/o/ogrsfdriver.o ./ogr/ogrsf_frmts/o/ogrsfdriverregistrar.o ./ogr/ogrsf_frmts/o/ogrshapedatasource.o ./ogr/ogrsf_frmts/o/ogrshapedriver.o ./ogr/ogrsf_frmts/o/ogrshapelayer.o ./ogr/ogrsf_frmts/o/ogrtigerdatasource.o ./ogr/ogrsf_frmts/o/ogrtigerdriver.o ./ogr/ogrsf_frmts/o/ogrtigerlayer.o ./ogr/ogrsf_frmts/o/ogrvrtdatasource.o ./ogr/ogrsf_frmts/o/ogrvrtdriver.o ./ogr/ogrsf_frmts/o/ogrvrtlayer.o ./ogr/ogrsf_frmts/o/s57classregistrar.o ./ogr/ogrsf_frmts/o/s57featuredefns.o ./ogr/ogrsf_frmts/o/s57filecollector.o ./ogr/ogrsf_frmts/o/s57reader.o ./ogr/ogrsf_frmts/o/s57writer.o ./ogr/ogrsf_frmts/o/shape2ogr.o ./ogr/ogrsf_frmts/o/shpopen.o ./ogr/ogrsf_frmts/o/shptree.o ./ogr/ogrsf_frmts/o/tigeraltname.o ./ogr/ogrsf_frmts/o/tigerarealandmarks.o ./ogr/ogrsf_frmts/o/tigercompletechain.o ./ogr/ogrsf_frmts/o/tigerentitynames.o ./ogr/ogrsf_frmts/o/tigerfeatureids.o ./ogr/ogrsf_frmts/o/tigerfilebase.o ./ogr/ogrsf_frmts/o/tigeridhistory.o ./ogr/ogrsf_frmts/o/tigerkeyfeatures.o ./ogr/ogrsf_frmts/o/tigerlandmarks.o ./ogr/ogrsf_frmts/o/tigeroverunder.o ./ogr/ogrsf_frmts/o/tigerpip.o ./ogr/ogrsf_frmts/o/tigerpoint.o ./ogr/ogrsf_frmts/o/tigerpolychainlink.o ./ogr/ogrsf_frmts/o/tigerpolygon.o ./ogr/ogrsf_frmts/o/tigerpolygoncorrections.o ./ogr/ogrsf_frmts/o/tigerpolygoneconomic.o ./ogr/ogrsf_frmts/o/tigertlidrange.o ./ogr/ogrsf_frmts/o/tigerzerocellid.o ./ogr/ogrsf_frmts/o/tigerzipcodes.o ./ogr/ogrsf_frmts/o/tigerzipplus4.o ./ogr/ogrgeometryfactory.o ./ogr/ogrpoint.o ./ogr/ogrcurve.o ./ogr/ogrlinestring.o ./ogr/ogrlinearring.o ./ogr/ogrpolygon.o ./ogr/ogrutils.o ./ogr/ogrgeometry.o ./ogr/ogrgeometrycollection.o ./ogr/ogrmultipolygon.o ./ogr/ogrsurface.o ./ogr/ogrmultipoint.o ./ogr/ogrmultilinestring.o ./ogr/ogr_api.o ./ogr/ogrfeature.o ./ogr/ogrfeaturedefn.o ./ogr/ogrfeaturequery.o ./ogr/ogrfeaturestyle.o ./ogr/ogrfielddefn.o ./ogr/ogrspatialreference.o ./ogr/ogr_srsnode.o ./ogr/ogr_srs_proj4.o ./ogr/ogr_fromepsg.o ./ogr/ogrct.o ./ogr/ogr_opt.o ./ogr/ogr_srs_esri.o ./ogr/ogr_srs_pci.o ./ogr/ogr_srs_usgs.o ./ogr/swq.o ./ogr/ogr_srs_validate.o ./ogr/ogr_srs_xml.o ./ogr/ograssemblepolygon.o ./ogr/ogr2gmlgeometry.o ./ogr/gml2ogrgeometry.o
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory `/export/home/oliver/tmp/gdal_par/gdal-1.2.0a'
make: *** [check-lib] Error 2
