[Gdal-dev] environment variable problem in Visual Studio .NET 2003
Fri Feb 27 10:36:13 EST 2004
David Lugan wrote:
> Hello GDAL-dev,
> The setenv and putenv have a bug in Visual Studio .NET 2003.  Anyone
> else have problems with this?
> My program calls _putenv("PROJ_LIB=C:\NAD"); so GDAL can use PROJ.DLL to
> warp properly
> When I work in Visual Studio .NET (2002) my program works great
> After installing Visual Studio .NET 2003 Pro my program only warps
> correctly sometimes
> MY SOLUTION THAT WORKS:
> Remove ALL putenv and getenv calls from the GDAL ( gdal-1.2.0a5 ) and
> PROJ4 ( proj-4.4.7 ) source code.
David,
I am not aware of anywhere in GDAL or PROJ.4 that calls putenv() in
the libraries.  Can you point me to such?  I generally avoid putenv(),
partly because of it's inconsistent affect in various kinds of DLL build
situations.
There is a mechanism for application code to call pj_set_finder() to
install a custom program to "find" PROJ.4 support files.  This is generally
the way applications are expected to override PROJ.4's search behaviour rather
than resetting environment variables.
Best regards,
