[Gdal-dev] Re: MinGW & GDAL: "[Linker error] undefined reference..."
J.Krueger
kruegerj at gmx.de
Tue Jul 27 16:35:18 EDT 2004
Frank Warmerdam wrote:
> I must confess I haven't been following this build issue closely. However,
> there is one major issue. GCC and GCC derived compilers used radically
> different "name munging" rules for C++ methods than MS Visual C++ does.
> So, in general you won't be able to interact with C++ objects from a VC++ built
> library from gcc.
That would mean if I actually succeeded in building my own c++ gdal
library with gcc I could use it, right? Or is that a code issue? If that
would work I'd be happy if someone could provide me with his working
library (if possible with support for the ERDAS .img format), as I tried
my luck with the library already - without success (most likely due to
my lack of experience).
> However, you should be able to use the GDAL C API as
> C function naming is uniform across compilers.
> So try implementing your code more along the lines of:
> int evaluate_Inputfiles(char* infile1, char* infile2) {
> GDALAllRegister();
> // Can the files be opened at all?
> int check=0;
> check=evaluate_Inputfile(infile1);
> if (check) return 1;
> check=evaluate_Inputfile(infile2);
> // Do they have the same size?
> const char* filename1=infile1;
> const char* filename2=infile2;
> GDALDatasetH highresDataset, lowresDataset;
> highresDataset = GDALOpen( filename1, GA_ReadOnly );
> rastersizex = GDALGetRasterXSize( highresDataset );
> rastersizey = GDALGetRasterYSize( highresDataset );
> int xsize1 = rastersizex;
> int ysize1 = rastersizey;
> return 0;
Mhh... the only change I see is that you're using 'GDALDatasetH' now
instead of GDALDataset. Is that all I'd have to change? As I said in my
first post - I'm a mere beginner as far as C/C++ is concerned. Basically
I'm using my need for the tool I work on as a motivation to learn C++,
so some stupid questions are to be expected... ;)
