[Gdal-dev] Compiling ogr/gdal on win32 using MingW
Mario Beauchamp starged at videotron.ca
Tue Jul 13 18:40:04 EDT 2004
Hi Alessandro and Wei Lee,
On Tue, 13 Jul 2004 21:53:11 +0200, Alessandro Amici <alexamici at fastwebnet.it> wrote:
>mingw on windows mostly works. the main problem is that you don't get python support.
It's possible to get Python support under MinGW but it requires some hacking...
>the static library is built out-of-the-box, i'm not sure if the dll is built
>as well. if not, you certainly can get it to build with a tiny bit of
>Makefile magic.
You can easily get the dll from the static lib.
>cross-compile from linux (debian with mingw32* packages) is not much harder
>than native bompile. it has the additional problem that the gdal configure
>system is not really coss-compile-proof ;). (--without-pg is your friend)
And "--without-libtool" :)
Wei Lee, contact me for more info...
Mario B.
