[Gdal-dev] Error messages with Configure
Steve Friedman
friedm69 at msu.edu
Tue Jul 27 12:40:15 EDT 2004
This is a follow-up regarding the errors I'm rec'ing as I try to
configure gdal.
# ./configure
checking build system type... sparc-sun-solaris2.8
checking host system type... sparc-sun-solaris2.8
checking target system type... sparc-sun-solaris2.8
checking for gcc... no
checking for cc... no
checking for cl... no
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details.
Inspecting the config.log file shows:
PATH: /usr/sbin
PATH: /usr/bin
However:
> which c++ returns
/opt/sfw/bin/c++
and
> which g++ returns
/opt/sfw/bin/g++
Furthermore, in setenv PATH is defined to include /opt/sfw/bin, which is
where these programs are located.
Why is configure only searching in /usr/bin and /usr/sbin?
Steve
