[Gdal-dev] problem of gdal_translate 1.1.9 and 1.2.1 with multiplebands
Xiaodong Zhang zhang at aero.und.edu
Wed Jul 28 10:41:25 EDT 2004
Thanks Frank,
Yes you are right, I have to use gdal_translate -b 1 -b 2 -b 3 ... to spectrally
subset an image, but it only works for version 1.2.1 but not for 1.1.9. Version
1.1.9 produces only one band regardless. Both ways of sending '-b' arguments,
i.e., -b 1,2,3,4 or -b 1 -b 2 -b 3 -b 3, work for earlier version, 1.1.8.
On aother note, are there any significant changes for versions later than 1.1.8.
In another email, I reported that our program using gdal api crashes for both
version 1.1.9 and 1.2.1, while it works perfectly for version 1.1.8.
Thanks again.
Xiaodong
Xiaodong Zhang, Ph.D.
Assistant Professor
Earth System Science and Policy Program
University of North Dakota
Grand Fors, ND 58202-9007
(701)777-6087
Quoting Frank Warmerdam <warmerdam at pobox.com>:
> Xiaodong Zhang wrote:
> > Then I run,
> > gdal_translate -b 1,2,3 -srcwin 100 100 200 200
> /mnt/dngp_images/3328_092002.tif
> > tmp.tif
> Hi,
> I think you need to use a seperate -b for each band requested.
> eg.
> gdal_translate -b 1 -b 2 -b 3 -srcwin 100 100 200 200
> /mnt/dngp_images/3328_092002.tif tmp.tif
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
