[Gdal-dev] Mosaic in GDAL Warp
David W. Lowther DLowther at scigis.com
Thu Jun 3 17:33:18 EDT 2004
Hi List,
I'm trying to use the mosaic with gdal warp. The docs say "Mosaicing
into an existing output file is supported if the output file already
exists."
I have four files (quarter quads). I'd like them mosaiced and
reprojected - either in one operation or more. I can make reproject
happen no prob for one file.
Here are some failed attempts to do this (note 109999 is custom defined
OK Albers Projection):
E:\GDAL\OpenEV_FW\data>..\bin\gdalwarp -s_srs EPSG:26715 -t_srs
EPSG:109999 -of GTIFF -co 'TFW=YES' e:\project\corps\38095a21.tif
e:\project\corps\out\a38095.tif
Creating output file is that 6440P x 7932L.
:0...10...20...30...40...50...60...70...80...90...100 - done.
EPSG:109999 -of GTIFF -co 'TFW=YES' e:\project\corps\38095a22.tif
Output dataset e:\project\corps\out\a38095.tif exists, but some
commandline options were provided indicating a new dataset should be
created.  Please delete existing dataset and run again.
EPSG:109999 -co 'TFW=YES' e:\project\corps\38095a22.tif
E:\GDAL\OpenEV_FW\data>..\bin\gdalwarp -s_srs EPSG:26715 -co 'TFW=YES'
e:\project\corps\38095a22.tif e:\project\corps\out\a38095.tif
23.tif e:\project\corps\out\a38095.tif
24.tif e:\project\corps\out\a38095.tif
Thanks in advance for any help anyone can provide.
David Lowther
Senior Software Engineer
Strategic Consulting International
(405) 227-9051
dlowther at scigis.com
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040603/30f53988/attachment.html
