[Gdal-dev] Small fix for geo_normalize.c in libgeotiff
Mon Jun 7 09:00:47 EDT 2004
Roger James wrote:
> In recent builds the name of the datum.csv has changed to
> gdal_datum.csv. This change has not been picked up in geo_nomalize.c.
> int GTIFGetDatumInfo( int nDatumCode, char ** ppszName, short *
> pnEllipsoid )
>     char    szSearchKey[24];
>     int           nEllipsoid;
>     const char *pszFilename = CSVFilename( "datum.csv" );
Roger,
I have changed the code to read:
     int		nEllipsoid;
     FILE       *fp;
/*      If we can't find datum.csv then gdal_datum.csv is an            */
/*      acceptable fallback.  Mostly this is for GDAL.                  */
     if( (fp = VSIFOpen(pszFilename,"r")) == NULL )
         pszFilename = CSVFilename( "gdal_datum.csv" );
     else
         VSIFClose( fp );
As might be deduced from the name, gdal_datum.csv is really GDAL specific.
It is the same as datum.csv with an extra column containing the equivelent
ESRI name for the datum.  I don't normally notice this problem because I have
the geotiff support files installed in /usr/local/share/epsg_csv.   However, in
a pure GDAL build using the internal libgeotiff this would be missing.
A more proper solution would likely be to have GDAL override the CSVFilename()
to apply this naming logic but that can be problematic in some situations
so I will take advantage of my role as maintainer of libgeotiff to hack in
GDAL specific support.
Best regards,
