[Gdal-dev] DEM projection conversion
Jean-Denis Giguere
jdenisgiguere at fastmail.fm
Mon Jun 7 17:56:02 EDT 2004
Hi list,
I have USGS-DEM data and I would like to convert them in rasters in
Lambert projection. I want to use these rasters with MapServer. I have
tried to convert them in several format (pcidsk, hfa and bt) with
gdalwarp, but the output rasters are always envelopped and I have bad
result when I use gdaltindex after.
This is a sample execution of gdalwarp, maybye I don't use correct
options...
$ gdalwarp -of BT \
-s_srs '+proj=latlong +datum=NAD83' \
-t_srs '+init=epsg:42304' \
some_dem_file some_dem_file.bt
Any idea to solve this problem will be greatly appreciated.
Thank you,
Jean-Denis
