[Gdal-dev] GDAL 1.2.0 Solaris build
Tue Mar 2 16:18:13 EST 2004
Frédéric Trastour wrote:
>>Frédéric,
>>You are setting up a pretty hard configuration!   I would suggest you
>>install the PROJ.4 tree, even if only into a local tree and then use
>>that to link against instead.  That will avoid the libtool related issues.
> It's what I done.
> The problem is that "/src" is automatically appended to the specified directory.
> The "make install" command in the PROJ4 build tree doesn't create a src
> dir in the install tree ( only include, lib, bin and share - and it's ok). So I have to create
> an 'src' in the PROJ installation tree and link the libproj.a library from lib to src.
> It's not a big problem, but It's look strange to me that 'src' is always appended...
Andrey,
Is this related to the way your new static proj support works?  Perhaps you
could look into it?
Best regards,
