[Gdal-dev] GDAL 1.2.0 Solaris build
Andrey Kiselev dron at ak4719.spb.edu
Wed Mar 3 06:54:28 EST 2004
On Tue, Mar 02, 2004 at 05:22:44PM +0100, Fr?d?ric Trastour wrote:
> The problem is that "/src" is automatically appended to the specified
> directory. The "make install" command in the PROJ4 build tree doesn't
> create a src dir in the install tree ( only include, lib, bin and
> share - and it's ok). So I have to create an 'src' in the PROJ
> installation tree and link the libproj.a library from lib to src.
I have commited a few tweaks for --with-static-proj4 test, could you
test this again?
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
