[Gdal-dev] Use of assert() on troublesome files
Andrey Kiselev dron at ak4719.spb.edu
Sat Mar 6 07:24:59 EST 2004
On Fri, Mar 05, 2004 at 05:09:49PM -0500, Ben Discoe wrote:
> I re-read your message, and you said to replace the jconfig.h AND
> don't change the order of the # define HAVE_BOOLEAN in tif_jpeg.c.
> So, i tried that, and rebuilt GDAL.
> Now, the major problem is fixed!  Wonderful!  Only a couple warnings
> are left, but no crash:
Well, this is fine and this is meant my workaround for boolean datatype
in tif_jpeg.c still doesn't work. Very bad... I shall try to come with
more comprehensive hack for that problem.
						Regards,
						Andrey
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
