[Gdal-dev] A build solution for VC7
Frank Warmerdam
warmerdam at pobox.com
Mon Mar 8 12:41:47 EST 2004
Roger James wrote:
> Frank,
> I have hacked up a build solution for gdal under vc7. Just uncompress
> that attached zip at the top level of the build tree. The only thing
> that may need changing is the location of the xerces includes in the
> additional include directories section of pre-processor section of the
> gdal projects and the xerces lib in the additional libraries section of
> the linker properties of the gdal dll project and statically linked
> utitlities projects. This should work alongside the normal nmake based
> build procedure. If you or anyone else wants to use/modify this, feel
> free to do so, on the understanding that I take no responsibility for it!
Roger,
Thanks. I'm not going to put it in CVS since there wouldn't be anyone
maintaining it, but at least it will be in the Email archive if someone
wants to grab it and update it.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
