[Gdal-dev] A build solution for VC7
Jason R Hughes
jason.hughes at elantech-inc.com
Mon Mar 8 13:40:14 EST 2004
Thanks that came in handy.
----- Original Message -----
To: gdal-dev at remotesensing.org
Sent: Monday, March 08, 2004 12:17 PM
Subject: [Gdal-dev] A build solution for VC7
Frank,
I have hacked up a build solution for gdal under vc7. Just uncompress that attached zip at the top level of the build tree. The only thing that may need changing is the location of the xerces includes in the additional include directories section of pre-processor section of the gdal projects and the xerces lib in the additional libraries section of the linker properties of the gdal dll project and statically linked utitlities projects. This should work alongside the normal nmake based build procedure. If you or anyone else wants to use/modify this, feel free to do so, on the understanding that I take no responsibility for it!
Roger
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040308/fb7c9e16/attachment.html
