[Gdal-dev] goode homolosine projection
Manuel Massing
gdal at warped-space.de
Wed Mar 10 11:05:13 EST 2004
Hello,
Attached is a small patch to add OGR support for the goode homolosine
projection.
Unfortunately, proj.4 does only support the uninterrupted form of the goode
projection, so a reprojection won't work on global datasets in interrupted
form.
However, in a local context, you can adjust false easting and central
meridian values for the different zones. For a listing of false easting and
central meridian values used in the interrupted form, refer to Table 1 of
http://edcdaac.usgs.gov/1KM/goodesarticle.asp.
To reproject e.g. a MODIS dataset of North America
(ftp://ftp.glcf.umiacs.umd.edu/modis/500m/North_America/Goodes.NA.2003321/),
you could use the command-line:
gdalwarp <input> -s_srs '+proj=goode +ellps=sphere +lon_0=100w
+x_0=-11119487.43' <output options>
cheers,
Manuel
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040310/29ab12fe/goode_projection.bin
