[Gdal-dev] Resampling with gdalwarp
Mario Beauchamp starged at videotron.ca
Sat Mar 20 21:14:54 EST 2004
Hi Andrey,
On Thu, 18 Mar 2004 11:23:52 +0300, Andrey Kiselev <dron at ak4719.spb.edu> wrote:
>I have attached several images to clarify a bit GDAL interpolation
>methods. Cubic B-spline in fact implements approximation, it has
>advantages over other methods on high upsampling rates.
I really would like to tell you it clarified but I can't :)
I guess I see things more in a practical way than analytically or in theory. For example, are some
methods better suited for some reprojections and/or resampling? And what about elevation data? For
example, the DEMs I have are in geographic projection and I need to reproject them to the
appropriate UTM zone to match the Landsat imagery of the same region. Since Landsat resolution is
30m, is it necessary to specify "-tr 30 30" or let gdalwarp figure that out?
It's the kind of questions I have :)
Thanks.
Mario B.
My Landsat images:
http://pages.infinit.net/starged/landsat/home.html
