[Gdal-dev] s-57 layer problem
Frank Warmerdam
warmerdam at pobox.com
Wed Mar 31 12:45:34 EST 2004
Fulko van Westrenen wrote:
> Hello,
> Until now I used a S-57 map-file containing all layers
> I needed. My real map consists of many files, and most
> of them do not contain all layers. The result looks like
> this:
> File "./test.gtk.py", line 593, in load_allmaps
> load_map(files[i])
> File "./test.gtk.py", line 574, in load_map
> bouyslat=load_objects(dataset,'BOYLAT')
> File "./test.gtk.py", line 513, in load_objects
> objects=dataset.GetLayerByName( name )
> File "/usr/lib/python2.3/site-packages/ogr.py", line 286, in GetLayerByName
> raise IndexError, 'No layer %s on datasource' % name
> IndexError: No layer BOYLAT on datasource
> Can someone tell me how to test for the existence of a layer
> before loading it?
Fulko,
You can iterate through all the layers to build a name list like this if
you want:
import ogr
ds = ogr.Open( '/u/data/s57/NO410810.000' )
names = []
for i in range(ds.GetLayerCount()):
names.append( ds.GetLayer(i).GetName())
print names
if ('BOYLAT' in names):
print 'have BOYLAT'
else:
print 'Dont have BOYLAT'
However, for your case it is likely just easier to use "try" to handle missing
layers.
eg.
try:
objects = dataset.GetLayerByName( name )
except:
return None
... use objects...
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
