[Gdal-dev] no makefile after configure
Frank Warmerdam
warmerdam at pobox.com
Mon May 3 16:24:35 EDT 2004
Henning Ries wrote:
> Hello,
> I tried to compile the latest source release (gdal-1.2.0b) on solaris,
> but there is no makefile after running configure:
> paris[hries] $ make
> make: Fatal error: No arguments to build
> Where is the problem?
Henning,
GDAL requires use of GNUmake, not just regular make. The makefile is called
GNUmakefile. Many suns seem to have GNUmake under the name "gmake" or
"gnumake". If not, you will need to install it from source.
PS. there is a gdal-1.2.0 final release available that is newer and better
than gdal-1.2.0b (which was a 1.2.0 beta).
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
