[Gdal-dev] GTOPO30 problem
Frank Warmerdam
warmerdam at pobox.com
Thu May 6 10:32:20 EDT 2004
Clay, Bruce wrote:
> Frank:
> Have you ever tried to open any of the GTOPO30 DEM files with GDAL?
> In particular the E20N90 file. I am getting some very large negative
> numbers from this file. Do I need to do anything in particular to
> handle ENDIAN issues or is it taken care of automatically.
> I retrieved the files from edcftp.cr.usgs.gov.
Bruce,
I have a dataset from a long time ago (W100N40) that has "BYTEORDER M"
at the beginning of the W100N40.HDR file. This tells the ESRI .HDR driver
that the data is big endian. I load this file and it seems to work fine.
However, it is possible I added this myself to correct for lacking info
in the file. What does your .HDR file look like?
Can you point me directly to the file in question?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
