[Gdal-dev] ogr2ogr-problems with lco="OVERWRITE=YES"
Stephan Holl
sholl at gmx.net
Thu May 6 10:55:12 EDT 2004
Dear developers,
while testing the new parameters for the GRASS-Module v.out.ogr I
stumbled over a problem, which I can reproduce with ogr2ogr as well.
When trying to overwrite an existing dataset in PostGIS the follwing
error occurs:
GRASS 5.7.-cvs:~ > ogr2ogr -f "PostgreSQL" PG:dbname=postgis gruen.shp
gruen -lco "OVERWRITE=YES" ERROR 1: CREATE TABLE "gruen" ( OGC_FID
SERIAL ) ERROR: Relation gruen_ogc_fid_seq already exists
ERROR 1: Terminating translation prematurely after failed
translation of layer gruen
The Layer is existent in PostGIS. What I did was extracting it in GRASS
(v.in.ogr), modifying it with v.digit, and trying to put it back to
PostGIS.
Both methods with v.out.ogr and ogr2ogr fail.
Perhaps someone knows whats going wrong.
Kind regards
Stephan Holl
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040506/a85994c9/attachment.bin
