[Gdal-dev] Re: [Openev-discuss] Fusion tool update
Frank Warmerdam
warmerdam at pobox.com
Thu May 6 21:32:03 EDT 2004
Mario Beauchamp wrote:
> Hi all,
> I have made some improvements to the Fusion tool. It is now possible to select an area to fuse using
> the ROI tool. Also the images don't have to be the same size, or even have the same resolution. The
> RGB image will be resampled to match the pan image resolution. However, this resampling is done
> using NN and this does not give good results when using color correction. It is not as noticeable
> with "regular" fusion.
> I hope there will be a way to specify the resampling algorithm of VRT datasets in Python in the
> future... any plans to implement that?
Mario,
It is my itention to implement a type of virtual datasource based on the
general GDAL image warper API. This should allow fairly generalized
image warping, as well as making the various resampling kernels available.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
