[Gdal-dev] Problems Linking with Stubs in the precompiled downloadable
Win32 Binaries.
Frank Warmerdam
warmerdam at pobox.com
Mon May 10 20:55:08 EDT 2004
Fam. Pool wrote:
> Linking...
> Creating library Debug/MapViewer.lib and object Debug/MapViewer.exp
> cMapVisual.obj : error LNK2001: unresolved external symbol "struct
> ogr_style_param * asStylePen" (?asStylePen@@3PAUogr_style_param@@A)
> cVectorLoader.obj : error LNK2001: unresolved external symbol "struct
> MapViewer.obj : error LNK2001: unresolved external symbol "struct
Louis,
I have reorganized the code using the asStyle*[] arrays in GDAL's CVS tree,
and this problem should no longer occur if you work against the latest GDAL
(the source snapshot to made later tonight).
I will try to prepare an OpenEV_FW release with all the latest libraries
in the next few days.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
