[Gdal-dev] Problems Linking with Stubs in the precompiled downloadable Win32 Binaries.
Pool
marisap at telkomsa.net
Tue May 11 02:00:49 EDT 2004
Frank,
Righto, I am indeed using Jasper Static Libs, built with the workspace
supplied with the Jasper source - is there a way to compile this to a
shared dll instead of libs? The workspace didn't seem to have that
set up.
But I'll try matching the options.
I understand that you don't want to put Static Libs up for download,
but like I said - any help would be appreciated - and mentioning that
the Jasper Static Lib might be the problem is probably the help I need.
Thanks,
Louis.
-----Original Message-----
[mailto:gdal-dev-admin at remotesensing.org]On Behalf Of Frank Warmerdam
Sent: 10 May 2004 11:31
To: gdal-dev at remotesensing.org; marisap at telkomsa.net
Subject: Re: [Gdal-dev] Problems Linking with Stubs in the precompiled
Fam. Pool wrote:
> I vainly tried removing the MSVCRT and LIBC default libs by adding
> /NODEFAULTLIB:LIBC and /NODEFAULTLIB:MSVCRT
> to LINKER_FLAGS in nmake.opt - but I guess you can imagine how many
> unresolved symbols I got then. Anyway, I'm using
> VC6 and I was wondering if that would cause any problems... I noticed your
> precompiled binaries specifically look for
> MSVCRT71.dll
Louis,
I will look into the asStyle issues though I can't promise when they will be
resolved. The other problems you are encountering are due to linking object
files with conflicting build options together. I gather you are linking
in a JasPer static library? It is likely built with different options
that GDAL. You will need to fiddle with stuff like the /MD flag in OPTFLAGS
in nmake.opt to match the options used for JasPer.
I would add that I have not every personally built with JasPer support on
windows. I use the alternate Kakadu library for my public builds and
have only used JasPer on linux.
> I don't want to whine 'cause I really hate whiners, but I would really
> appreciate it if you could direct me to a site
> where I can download precompiled WIN32 Static Libs for GDAL and OGR. Or
put
> one up if there aren't any - actually any help
> would be dearly appreciated!
Well, I don't normally like to distribute static libraries because they
introduce all sorts of extra C library and other dependencies, and make
linking more complex. Folks run into problems just like you have, and they
can be very hard for me to resolve remotely.
If you need the style support you are faced with dealing with the static
build issues mostly on your own.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
