[Gdal-dev] gdalwarp
Norman Barker
normanb at comsine.co.uk
Wed May 12 14:20:30 EDT 2004
looking at the warp utility am I correct in thinking that the restriction on 8 bit tiff, and holding all the tiff in memory is now removed.
GDAL 1.1.8
'implemented new 'gdalwarp' application for projection and GCP based image
warping. See gdal/alg for underlying algorithms. Currently gdalwarp only
supports 8 bit images and holds the whole source image in memory.'
As I am a bit new to this, and in particular GDAL say I had a geotiff in in UTM WGS84 (EPSG:32630) how would I convert it to Lat/long WGS84 (EPSG:4326) ?
Many thanks,
Norman Barker
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040512/7bfcc6f6/attachment.html
