[Gdal-dev] gdalwarp
Frank Warmerdam
warmerdam at pobox.com
Wed May 12 15:35:55 EDT 2004
Norman Barker wrote:
> Hi,
> looking at the warp utility am I correct in thinking that the
> restriction on 8 bit tiff, and holding all the tiff in memory is now
> removed.
> GDAL 1.1.8
> 'implemented new 'gdalwarp' application for projection and GCP based image
> warping. See gdal/alg for underlying algorithms. Currently gdalwarp
> only
> supports 8 bit images and holds the whole source image in memory.'
Norman,
Yes, I believe the new generalized warper was in place for the 1.1.9 release
and certainly for 1.2.0.
> As I am a bit new to this, and in particular GDAL say I had a geotiff in
> in UTM WGS84 (EPSG:32630) how would I convert it to Lat/long WGS84
> (EPSG:4326) ?
Assuming the input file is properly labelled as UTM you would just do:
gdalwarp -t_srs EPSG:4326 in.tif out.tif.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
