[Gdal-dev] Quick Question Regarding Style String Management
L Pool
marisap at telkomsa.net
Sat May 15 13:27:29 EDT 2004
Ok. Here's another one -
Is there a function in the Style Library that can parse the Pattern String
of a Pen Tool - or should I parse it myself? I know I'm being a bit lazy - I
can easily use the "px" chars as token delimiters - but I would like to know
whether there are functions (ones that I might be missing) to parse the
Parameters one gets from the Style Tools.
Thanks,
Louis.
-----Original Message-----
[mailto:gdal-dev-admin at remotesensing.org]On Behalf Of L Pool
Sent: 15 May 2004 06:52
To: gdal-dev at remotesensing.org
Subject: [Gdal-dev] Quick Question Regarding Style String Management
Hi Frank,
I've got a quick question for you - regarding the code below: which of these
objects should I delete when I'm finished with it - the Style Manager and
the Style Tool or just the Style Manager?
OGRStyleTable oStyleTable;
OGRStyleTool* poStyleTool;
OGRStyleMgr* poStyleMgr = new OGRStyleMgr(&oStyleTable);
poStyleMgr->GetStyleString(poFeature);
for (int k=0; k < poStyleMgr->GetPartCount(); k++)
poStyleTool = poStyleMgr->GetPart(k);
switch(poStyleTool->GetType())
case OGRSTCNone: cout << "Tool Type: None" << endl;
break;
case OGRSTCPen: cout << "Tool Type: Pen" << endl;
break;
case OGRSTCBrush: cout << "Tool Type: Brush" << endl;
break;
case OGRSTCSymbol: cout << "Tool Type: Symbol" << endl;
break;
case OGRSTCLabel: cout << "Tool Type: Label" << endl;
break;
Thanks in advance,
Louis Pool.
BTW: Everything seems to be working super now with the new OpenEV_FW
binaries.
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
