[Gdal-dev] Quick Question Regarding Style String Management
Frank Warmerdam
warmerdam at pobox.com
Sat May 15 12:58:03 EDT 2004
L Pool wrote:
> Hi Frank,
> I've got a quick question for you - regarding the code below: which of these
> objects should I delete when I'm finished with it - the Style Manager and
> the Style Tool or just the Style Manager?
> OGRStyleTable oStyleTable;
> OGRStyleTool* poStyleTool;
> OGRStyleMgr* poStyleMgr = new OGRStyleMgr(&oStyleTable);
> poStyleMgr->GetStyleString(poFeature);
> for (int k=0; k < poStyleMgr->GetPartCount(); k++)
> poStyleTool = poStyleMgr->GetPart(k);
> switch(poStyleTool->GetType())
> case OGRSTCNone: cout << "Tool Type: None" << endl;
> break;
> case OGRSTCPen: cout << "Tool Type: Pen" << endl;
> break;
> case OGRSTCBrush: cout << "Tool Type: Brush" << endl;
> break;
> case OGRSTCSymbol: cout << "Tool Type: Symbol" << endl;
> break;
> case OGRSTCLabel: cout << "Tool Type: Label" << endl;
> break;
> Thanks in advance,
Louis,
You need to delete the style tool and the style manager. I see the
style API has no reference documentation. That sucks.
> BTW: Everything seems to be working super now with the new OpenEV_FW
> binaries.
Sweet.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
