[Gdal-dev] Re: MinGW & GDAL: "[Linker error] undefined reference..."
Chapman, Martin
MChapman at sanz.com
Thu May 27 23:22:52 EDT 2004
Try this:
#include <iostream>
#include "gdal_priv.h"
int nRasterX = 0, nRasterY = 0, nNumberOfBands = 0;
string sFileName = "c:\\somefile.tif";
GDALAllRegister();
GDALDataset* pDataset = (GDALDataset*) GDALOpen(sFileName.c_str(), GA_ReadOnly);
if ( pDataset == NULL )
cout << (char*) CPLGetLastErrorMsg() << endl;
return false;
nNumberOfBands = pDataset->GetRasterCount();
cout << "Num Bands: " << nNumberOfBands << endl;
if (nNumberOfBands > 0)
nRasterX = pDataset->GetRasterBand(1)->GetXSize();
nRasterY = pDataset->GetRasterBand(1)->GetYSize();
cout << "RasterX: " << nRasterX << "\nnRasterY: " << nRasterY << endl;
if (pDataset)
GDALClose(pDataset);
I just cut and pasted some code, so it might need a couple of tweaks. Send me what the output is from this code. What platform are you running this on? If it's visual studio on windows you need to link the gdal_i.lib in your project settings. If you are using Linux it needs to be linked in the make file.
Martin
-----Original Message-----
Sent: Mon 7/26/2004 7:13 PM
To: gdal-dev at remotesensing.org
Cc:
Subject: [Gdal-dev] Re: MinGW & GDAL: "[Linker error] undefined reference..."
Ok, I thought I had managed it, but while I can open files now, I am now
getting this damn error again - only this time not for all gdal
instructions. For example I can open/close datasets, but I can't query
them for certain (any?) information:
-cut-
Dataset1 = (GDALDataset *) GDALOpen( filename1, GA_ReadOnly );
int xsizefile1 = Dataset1->GetRasterXSize();
int ysizefile1 = Dataset1->GetRasterYSize();
-cut-
results in the following error messages:
[Linker error] undefined reference to `GDALDataset::GetRasterXSize()'
[Linker error] undefined reference to `GDALDataset::GetRasterYSize()'
The mere opening of the Dataset does not cause any problems. As soon as
I uncomment the GetRasterXSize/GetRasterYSize instructions the program
compiles properly and the Image files can be accessed.
Any ideas? Do I have to add something more to my compiler/linker
switches, or is it just a problem with the code? If I'm still missing a
switch: where can I find some detailed info/documentation on what is
needed, so I don't have to ask here every time?
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040527/7702014a/attachment.bin
