[Gdal-dev] line of sight
Frank Warmerdam
warmerdam at pobox.com
Tue Nov 2 19:42:21 EST 2004
Bodoh wrote:
> Hi all
> Is GDAL able to find the line of sight between 2
> points?
Richards,
Not by itself. You can however use GDAL to read various DEM formats
into memory and then "walk through the array" between the points to
determine if you have LOS.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
