[Gdal-dev] GDAL, and C# Access
Thu Nov 4 11:55:45 EST 2004
Folks,
There has been talk from time to time about using GDAL from C# or as a .NET
assemblage.  I can't say I grok all the issues in this area, but I thought
I should pass on something Roger Bedell sent me over a year ago.  He sent
a whole project showing how GDAL could be called from C#, which I am finally
looking at briefly.  I couldn't actually run the project, but I did dig
through the code, and found the following was the core of the GDAL
interaction.
The point is that it is fairly easy to call out to C entry points from C#.
At some point I might well try and maintain an appropriate set of C#
declarations for the GDAL C API though I am not ready to do that just yet.
		/// <summary>
		/// The main entry point for the application.
		/// </summary>
		[STAThread]
		static void Main()
			Application.Run(new Form1());
		public enum GA_Access
			/*! Read only (no update) access */ GA_ReadOnly = 0,
			/*! Read/write access. */           GA_Update = 1
		[DllImport("gdal11.dll")]
		public static extern IntPtr
			GDALOpen( string pszFilename, GA_Access eAccess );
			GDALGetDatasetDriver( IntPtr GDALDatasetH );
		public static extern void
			GDALAllRegister();
		[DllImport("gdal11.dll",CharSet=CharSet.Ansi)]
		public static extern string
			GDALGetDriverShortName( IntPtr GDALDriverH );
			GDALGetDriverLongName( IntPtr GDALDriverH );
		public static extern int GDALGetRasterXSize( IntPtr GDALDatasetH );
		public static extern int GDALGetRasterYSize( IntPtr GDALDatasetH );
		public static extern int GDALGetRasterCount( IntPtr GDALDatasetH );
		public static extern string GDALGetProjectionRef( IntPtr GDALDatasetH );
		public enum CPLErr
			CE_None = 0,
			CE_Debug = 1,
			CE_Warning = 2,
			CE_Failure = 3,
			CE_Fatal = 4
		public static extern CPLErr GDALGetGeoTransform( IntPtr GDALDatasetH, [In,Out] double [] Transform );
		GDALGetDriverByName( string s );
		GDALCreateCopy( IntPtr GDALDriverH, string s, IntPtr GDALDatasetH,
						int i, IntPtr j, IntPtr k, IntPtr l);
			GDALClose( IntPtr GDALDriverH );
			GDALDestroyDriverManager();
		private void button1_Click(object sender, System.EventArgs e)
			GDALAllRegister();
			IntPtr hDataset = GDALOpen( Application.StartupPath + "\\..\\..\\SampleData\\SARA_IRS.TIF", GA_Access.GA_ReadOnly);
			if( hDataset == (IntPtr)null )
				MessageBox.Show("Could not open Raster File.");
			IntPtr   hDriver;
			hDriver = GDALGetDatasetDriver( hDataset );
			//This seems to wig out .NET...Looks to me GDAL has become unstable due to this call.
//			MessageBox.Show("Driver: " + GDALGetDriverShortName( hDriver ) + " " + GDALGetDriverLongName( hDriver ) );
			MessageBox.Show("Size is " + GDALGetRasterXSize( hDataset ) + " " + GDALGetRasterYSize( hDataset ) + " " +
GDALGetRasterCount( hDataset ) );
//			string ProjectionRef = null;
			//Also this call destabilized the stack. Looks to me like strings are not handled
			//the way they should be by .NET.
//			ProjectionRef = GDALGetProjectionRef( hDataset );
//			if( ProjectionRef != null )
//				MessageBox.Show("Projection is " + ProjectionRef );
			double [] adfGeoTransform = new double[6];
			if( GDALGetGeoTransform( hDataset, adfGeoTransform ) == CPLErr.CE_None )
				MessageBox.Show( "Origin = " + adfGeoTransform[0] + " " + adfGeoTransform[3] );
				MessageBox.Show( "Pixel Size = " +	adfGeoTransform[1] + " " + adfGeoTransform[5] );
			//Convert to some other format (JPG for example)
			hDriver = GDALGetDriverByName( "JPEG" );
			//Do a straight copy.
			IntPtr hOutDS = GDALCreateCopy( hDriver, Application.StartupPath + "\\..\\..\\SampleData\\SARA_IRS.JPG", hDataset,
				0, (IntPtr)null,
				(IntPtr)null, (IntPtr)null);
			if(hOutDS != (IntPtr)null)
				GDALClose( hOutDS );
			//Shut everything down.
			GDALClose( hDataset );
			MessageBox.Show("Export to JPEG complete.");
Best regards,
