=?GB2312?B?tPC4tDogWyoqKlNQQU0qKiogU2NvcmUvUmVxOiAwOS41MC8wNQ==?=
=?GB2312?B?LjAwXSBbR2RhbC1kZXZdIFJlOiBtdWx0aWJhbmQgb3ZlcnZpZXcgcHJvYmxlbQ==?=
=?GB2312?B?cw==?=
Frank Warmerdam
warmerdam at pobox.com
Thu Nov 11 09:30:13 EST 2004
wlx wrote:
> Hi Mr. Warmerdam,
> I will upgrade my gdal to the cvs version,and is my work just
> recompile the gdal? And then this question will be solved?
> Thank you very much.
LiangXu,
Well, it depends on your environment of course. If you are
using the internal libtiff then updating from CVS, rebuilding and
installing the software should be sufficient.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
