[Gdal-dev] GDAL 1.2.5 Released
ksa nil5-ksa at yandex.ru
Tue Nov 23 01:54:10 EST 2004
Hi, Frank, hi, Daniel.
Resently I wrote to you about font name in style string for point features.
There is no ability to get this information.
I wrote, that I have developed a patch (only for MapInfo files), which helps
to get that information.
You answered that you will discuss that.
But up to the point you do not answered your suggestion...
I think that many peoples works with MapInfo files through OGR and shold
like to get full style information for all features.
Respectfully yours, Sergey Karin.
> Folks,
> I have a cut a new version of GDAL, primariliy to cleanup the issue with
> overviews stored in GeoTIFF format since I did not copy the updated
libtiff
> code into the distribution itself for 1.2.4.
> This release also includes an overhaul of the Oracle Spatial vector reader
> with fixes, and new features (table list in datasource name, Oracle 10g
support).
> Grab it from:
>    http://www.gdal.org/dl/gdal-1.2.5.tar.gz
>    http://www.gdal.org/dl/gdal125.zip
>  From the NEWS file:
> GDAL 1.2.5 - Overview of Changes
> gdalwarp Utility:
>   - Added "proper" source and destination alpha support.
> PCRaster Driver:
>   - added write support, now consider ready for regular use.
> MrSID Driver:
>   - Initial support for writing to MrSID with encoding SDK.
> GeoTIFF Driver:
>   - Updated internal copy of libtiff to fix overview building ... really!
>   - Fixed bug when writing south-up images.
> OGR 1.2.5 - Overview of Changes
> OGRSpatialReference:
>   - Added Bonne projection.
> Docs:
>   - Added OGR C++ API Tutorial (reading and writing).
> PostGIS Driver:
>   - Implemented SetFeature() and DeleteFeature() methods for in-place
updates.
> Oracle (OCI) Driver:
>   - Fixed support for writing into Oracle 10g.
>   - Fixed serious memory leak of geometries.
>   - Fixed bug with 3D multipolygons.
>   - Added support for selecting tables in the datasource name.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
