[Gdal-dev] New user needs helps
Martin Hodder mhodder at highermappingsolutions.com
Tue Nov 30 17:27:56 EST 2004
I hope someone can help me.
I am trying to convert some points in Long / lat format to World Equidistant
Cylindrical projection
I have the following information on the projection:-
PROJCS["World_Equidistant_Cylindrical",
GEOGCS["GCS_WGS_1984",
DATUM["D_WGS_1984",
SPHEROID["WGS_1984",6378137.0,298.257223563]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Equidistant_Cylindrical"],
PARAMETER["False_Easting",0.0],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",0.0],
PARAMETER["Standard_Parallel_1",60.0],
UNIT["Meter",1.0]]
The Long lat points are in MapInfo Format and it can be the same or a shp
file as an output.
Can anyone tell how I format the ogr2ogr statement?
Many thanks
Martin
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20041130/ffd4f854/attachment.html
