[Gdal-dev] gdalwarp - again!
Norman Barker
normanb at comsine.co.uk
Tue Nov 30 05:20:39 EST 2004
I have built proj from CVS and got the same error.
I removed all reference to this from my machine and
installed FWTools 0.9.4
but running gdalwarp -t_srs wgs84 latlong.tif out.tif
causes
ERROR 1: geocentric transformation missing z or ellps
ERROR 1: GDALWarperOperation::ComputeSourceWindow() failed because
the pfnTransformer failed.
So the error is identical with the latest build of FWTools or the CVS
version of Proj.
I have tried the fix of pj_transform.c as previously suggested when
building from source.
I am running Fedora Core 2, and though I am not an expert user, I have
made sure
that I am clean of any previous gdal libraries.
Any help would be appreciated.
Norman
Norman Barker
Software Engineer
ComSine Ltd
Tel: +44 (0)1483 457121
Web: http://www.comsine.com
*Please Note:*
This text is confidential. If you are not the named addressee, it could be unlawful for you to read, copy, distribute, disclose or use the information contained herewith. If you are not the intended recipient please telephone +44(0)1483 457121.
