[Gdal-dev] pct2rgb.py
Gillian Walter gillian.walter at atlantis-scientific.com
Thu Oct 14 14:26:43 EDT 2004
Hi Frank,
Does openev 1.82 include the latest compose.py tool?  If it does, I think the
compose and export tools could also be used to do the merge (load the three
images up in openev, launch the compose tool, set the three output bands, display
the result, then run the export tool- it should be able to export the vrt lines
created by the compose tool).  This is more steps than gdal_merge, but avoids the
command line for those who prefer gui's.
Gillian
Frank Warmerdam wrote:
> Dobmeyer, Todd wrote:
> > I honestly do not remember how I built gdal, if I did it with python
> > support or not. I might rebuild this to make sure that I do add python
> > support. I am on Windows XP Pro and am very new to gdal yet. To make
> > sure I get python support, I should go out and find one of the OpenEV_FW
> > builds? Or what exactly should I do? Thanks for your continued help and
> > I am glad I chose to work with gdal!
> Todd,
> If you don't need to build everything yourself, I would suggest just
> using the OpenEV_FW release for this task.
>    http://gdal.org/dl/openev/OpenEV_FW_182.zip
> It includes everything built nicely together, including the Python numeric
> package which would be needed for gdal_merge.py to work (as noted by another
> user).  On Windows when building GDAL you need to explitely set the PYDIR
> in nmake.opt to get python support working.  I think there are some additional
> complications related to the numeric support.  This is within your ability to
> handle, but unless you need to build things yourself for some reason I would
> suggest you avoid it.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
