[Gdal-dev] pct2rgb.py
Frank Warmerdam
warmerdam at pobox.com
Thu Oct 14 15:19:37 EDT 2004
Gillian Walter wrote:
> Hi Frank,
> Does openev 1.82 include the latest compose.py tool? If it does, I think the
> compose and export tools could also be used to do the merge (load the three
> images up in openev, launch the compose tool, set the three output bands, display
> the result, then run the export tool- it should be able to export the vrt lines
> created by the compose tool). This is more steps than gdal_merge, but avoids the
> command line for those who prefer gui's.
Gillian,
I think it would include all compose updates.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
