[Gdal-dev] OGR spatial indexes in Oracle
bluecarto at free.fr
Fri Oct 15 10:21:01 EDT 2004
That works, although this limits in some way.
Is there any way to use the views in oracle with OGR ?
Regards
Pierre
Selon Frank Warmerdam <warmerdam at pobox.com>:
> GIRAUD Pierre wrote:
> > ----> with ogrinfo :
> > aneto:~$ ogrinfo OCI:scott/tiger at aneto/orcl -sql "select a.geometry from
> > ref_batiment a" -spat 58750573 13847995 58751000 13900000
> > INFO: Open of `OCI:pierre/xbe9a51h at aneto.oco/orcl'
> > using driver `OCI' successful.
> > Layer name: select a.geometry, a.genre from ref_batiment a
> > Geometry: Unknown (any)
> > Feature Count: 97587
> > The time to get the info is obviously not the same.
> > What is the way I missed to get it working ?
> Pierre,
> I have reviewed the OCI driver code, and it seems that the spatial query
> information is currently ignored in the case of an SQL query against oracle.
> For now you will either have to include the spatial query within your SQL
> statement or do spatial queries directly against the table like this:
> ogrinfo OCI:scott/tiger at aneto/orcl ref_batiment -spat 58750573 13847995
> 58751000 13900000
> I would encourage you to submit a Buzgilla bug report on this issue if you
> would
> like it resolved. I don't have access to a working Oracle instance at this
> time
> so it may be a while before I can resolve the issue.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
