[Gdal-dev] OGR spatial indexes in Oracle
Frank Warmerdam
warmerdam at pobox.com
Fri Oct 15 10:50:30 EDT 2004
bluecarto at free.fr wrote:
> That works, although this limits in some way.
> Is there any way to use the views in oracle with OGR ?
Pierre,
Currently the OCI driver does the following query to get the list of
tables to be treated as layers:
SELECT TABLE_NAME, COLUMN_NAME, SRID, OWNER FROM ALL_SDO_GEOM_METADATA
If views appear in ALL_SDO_GEOM_METADATA then they should be usable as
layers. If not, they wont.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
