[Gdal-dev] RE: MapServer WCS
Martin Daly Martin.Daly at cadcorp.com
Tue Oct 19 12:23:44 EDT 2004
Frank,
> If you want an externally accessable libtiff API the best way
> is to build libtiff seperately from GDAL and then link GDAL
> against that.  The normal libtiff build mechanisms do export
> all the entry points (using a .def file) while GDAL does not.
>  One could argue whether GDAL should, or whether it is better
> for GDAL to "hide" it's copy of libtiff internally, but I am
> not keen to try and change this.
Done.  Works a treat.
Thanks,
Martin
