[Gdal-dev] Memory leak in OCI
Lorenzo Maior.it
lorenzo.sassolini at maior.it
Fri Oct 22 12:00:33 EDT 2004
Hello,
I've used the standard loop:
while ((aOGRFeatureH = OGR_L_GetNextFeature(aLayerH)) != NULL)
OGR_F_Destroy(aOGRFeatureH);
with an OCILayer containing only geometries of type "wkbLineString".
It seams that memory isn't freed.
If I read the same geometries with the same loop but from a shapefile I
don't have any memory problem.
Do anyone know the problem?
Thanks!
Lorenzo
Lorenzo Sassolini
Lorenzo.Sassolini at maior.it
Maior srl
Via XXIV Maggio, 3
50100 Firenze (ITALY)
Tel. +39 055 482959
Fax. +39 055 476891
info at maior.it
http://www.maior.it
