[Gdal-dev] Re: Gdal-dev Digest, Vol 4, Issue 9
Steve Halasz
debian at adkgis.org
Fri Sep 10 12:13:35 EDT 2004
On Fri, 2004-09-10 at 11:38, Stephan Holl wrote:
> Hello Steve,
> On Thu, 9 Sep 2004 14:58:38 -0400 (EDT)
> gdal-dev-request at xserve.flids.com wrote:
> > Try adding /home/steph/cvs/grass57_cvs/dist.i686-pc-linux-gnu/lib to
> > /etc/ld.so.conf and running ldconfig.
> Thanks for the suggestion. I already did that, but the same error
> appears.
Did you run autoconf after applying the patch?
Steve
