[Gdal-dev] Re: Gdal-dev Digest, Vol 4, Issue 9
Stephan Holl
sholl at gmx.net
Fri Sep 10 15:30:10 EDT 2004
Hello Steve,
On Fri, 10 Sep 2004 12:26:31 -0400 Steve Halasz <debian at adkgis.org>
wrote:
> Stephan,
> Where did you get the patch? I suspect it is out of date. Try
> replacing grassdataset.cpp with:
> http://mpa.itc.it/radim/qgis/gdal/grassdataset.cpp3
> And be sure you are using this patch for configure.in:
> http://mpa.itc.it/radim/qgis/gdal/configure.in.patch2
finally I did a fresh checkout, applied the above mentioned patches
again, run autoconf, ./configure and make.
Everything went fine now. Mystery things are going on...
Anyway, thanks for your help!
Cheers
Stephan
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040910/7733859c/attachment.bin
