[Gdal-dev] Raster splitting program
Homme Zwaagstra hrz at geodata.soton.ac.uk
Wed Sep 15 11:40:31 EDT 2004
Hello,
I thought I'd post a program that I've written in the hope that it may
be of use to someone else. The program does the opposite of the
gdal_merge.py script by splitting a raster up into georeferenced
tiles.  I've found it useful for making large rasters more manageable,
especially in conjunction with the UMN MapServer and the gdaltindex
program.
It is a C++ program based on the gdal_translate code (specifically the
stuff that implements the -srcwin modifier). I've developed it under
linux using GCC and GDAL 1.2.0.0 (released 2004/03/10):
$ uname -a
Linux alf 2.4.21-15.0.3.ELsmp #1 SMP Tue Jun 29 18:04:47 EDT 2004 i686
i686 i386 GNU/Linux
$ gcc --version
gcc (GCC) 3.2.3 20030502 (Red Hat Linux 3.2.3-34)
I've been compiling it using the following command:
gcc -o gdalsplit -L/usr/local/lib -lgdal -I/usr/local/include -I/root/src/gdal-1.2.0/frmts -ltiff gdalsplit.cpp -Wall
I'm unable to support the program on any other system. I also have to
admit to being a newbie with C/C++ as well as the GDAL API, so the
disclaimer "use at your own risk" is particularly applicable here!
Attached is the C++ file and man page in nroff format.  The output of
the man page is:
NAME
       gdalsplit - splits raster datasource(s) into tiles
SYNOPSIS
       Usage: gdalsplit [--version]
              [-c cols]
              [-r rows]
              [-quiet]
              src_dataset...
DESCRIPTION
       Split one or more raster datasources into more manageable tiles. This
       is, for instance, useful in conjunction with the gdaltindex program.
       The output files are created in the same directory as the source files.
       The source dataset is not deleted.
       The output datasets are not guaranteed to be of equal pixel size unless
       the columns and rows specified exactly divide into the source dataset
       width and height respectively.
       -c cols:
           Select the number of columns cols to split the source dataset into.
           The default is 2.
       -r rows:
           Select the number of rows rows to split the source dataset into.
           The default is 2.
       -quiet:
           Supress progress monitor and other non-error output.
       src_dataset:
           The source file name.
EXAMPLE
       % gdalsplit -c 3 -r 3 utm.tif
       produces the following 9 files:
       utm_c1_r1.tif
       utm_c1_r2.tif
       utm_c1_r3.tif
       utm_c2_r1.tif
       utm_c2_r2.tif
       utm_c2_r3.tif
       utm_c3_r1.tif
       utm_c3_r2.tif
       utm_c3_r3.tif
Thanks,
Homme Zwaagstra
 * Purpose:  GDAL Image Splitting Program
 * Author:   Homme Zwaagstra, geodata at soton.ac.uk
 * This program is heavily derived from the GDAL gdal_translate utility
 * Copyright (c) 1998, 2002, Frank Warmerdam
 * Permission is hereby granted, free of charge, to any person obtaining a
 * copy of this software and associated documentation files (the "Software"),
 * to deal in the Software without restriction, including without limitation
 * the rights to use, copy, modify, merge, publish, distribute, sublicense,
 * and/or sell copies of the Software, and to permit persons to whom the
 * Software is furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included
 * in all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
 * OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
 * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
 * DEALINGS IN THE SOFTWARE.
#include "cpl_string.h"
#include "vrt/vrtdataset.h"
/* compilation on WIN32 machines has not been tested! */
#ifdef WIN32
#define PATH_SEP_CHAR '\\'
#else
#define PATH_SEP_CHAR '/'
#endif
static CPLErr CopyRasterBand(GDALDataset *poSrcDS, GDALDataset *poDstDS, int nBand, int nSrcXOff, int nSrcYOff, int nSrcXSize, int nSrcYSize);
static VRTDataset * CopyRasterWindow(GDALDatasetH hSrcDS, int nSrcXOff, int nSrcYOff, int nSrcXSize, int nSrcYSize);
static void AttachMetadata( GDALDatasetH, char ** );
static int SplitFile(const char *pszSource, int cols, int rows, int bQuiet, GDALProgressFunc pfnProgress);
static char * CreateString(const char *fmt, ...);
static char * CreateFileName(const char *pszSource, int col, int row);
static char * GetExtension(const char *basename);
static char * GetDirname(const char *string);
static char * GetBasename(const char *string);
/*                               Usage()                                */
static void Usage()
    int	iDr;
    printf( "Usage: gdalsplit [--version]\n"
            "       [-c cols]\n"
            "       [-r rows]\n"
            "       [-quiet]\n"
            "       src_dataset...\n\n" );
    printf( "%s\n\n", GDALVersionInfo( "--version" ) );
    printf( "The following format drivers are configured and support output:\n" );
    for( iDr = 0; iDr < GDALGetDriverCount(); iDr++ )
			GDALDriverH hDriver = GDALGetDriver(iDr);
			if( GDALGetMetadataItem( hDriver, GDAL_DCAP_CREATE, NULL ) != NULL
				|| GDALGetMetadataItem( hDriver, GDAL_DCAP_CREATECOPY,
										NULL ) != NULL )
					printf( "  %s: %s\n",
							GDALGetDriverShortName( hDriver ),
							GDALGetDriverLongName( hDriver ) );
/*                                main()                                */
int main( int argc, char ** argv )
	int bQuiet = FALSE, i, j = 0;
	int cols = 2, rows = 2;
    GDALProgressFunc pfnProgress = GDALTermProgress;
/*      Register standard GDAL drivers, and identify output driver.     */
    GDALAllRegister();
/*      Handle command line arguments.                                  */
	for( i = 1; i < argc; i++ ) {
		if( EQUAL(argv[i],"--version") )
				printf( "%s\n", GDALVersionInfo( "--version" ) );
        else if( EQUAL(argv[i],"-quiet") )
				bQuiet = TRUE;
				pfnProgress = GDALDummyProgress;
		else if( EQUAL(argv[i],"-c") )
				if( atoi(argv[i+1]) < 2 )
						printf( "There must be more columns than %s.\n", argv[i+1] );
						Usage();
						GDALDestroyDriverManager();
						exit( 2 );
				cols = atoi(argv[++i]);
		else if( EQUAL(argv[i],"-r") )
						printf( "There must be more rows than %s.\n", argv[i+1] );
						Usage();
						exit( 2 );
				rows = atoi(argv[++i]);
        else if( argv[i][0] == '-' )
				printf( "Option %s incomplete, or not recognised.\n\n",
						argv[i] );
				Usage();
				exit( 2 );
        else {
			SplitFile(argv[i], cols, rows, bQuiet, pfnProgress);
			j++;
	/* At least one file must be provided */
	if (j == 0) {
		Usage();
		exit( 2 );
/*      Clean up.                                                       */
	GDALDumpOpenDatasets( stderr );
	exit(0);
/*                           AttachMetadata()                           */
static void AttachMetadata( GDALDatasetH hDS, char **papszMetadataOptions )
    int nCount = CSLCount(papszMetadataOptions);
    int i;
    for( i = 0; i < nCount; i++ )
			char    *pszKey = NULL;
			const char *pszValue;
			pszValue = CPLParseNameValue( papszMetadataOptions[i], &pszKey );
			GDALSetMetadataItem(hDS,pszKey,pszValue,NULL);
			CPLFree( pszKey );
    CSLDestroy( papszMetadataOptions );
/*                           CopyRasterBand()                           */
/*      Add a copy of the specified source band to the destination      */
/*      dataset using only data from a pixel window.                    */
	VRTRasterBand   *poVRTBand;
	GDALRasterBand  *poSrcBand;
	GDALDataType    eBandType;
	double          dfNoData;
	int             bSuccess;
	poSrcBand = poSrcDS->GetRasterBand( nBand );
/*      Select output data type to match source.                        */
	eBandType = poSrcBand->GetRasterDataType();
/*      Create this band.                                               */
	if (poDstDS->AddBand( eBandType, NULL ) == CE_Failure)
		return CE_Failure;
	poVRTBand = (VRTRasterBand *) poDstDS->GetRasterBand( nBand );
/*      Create a simple data source.                                    */
	poVRTBand->AddSimpleSource( poSrcBand,
								nSrcXOff, nSrcYOff,
								nSrcXSize, nSrcYSize,
								0, 0,
								nSrcXSize, nSrcYSize );
/*      copy over some other information of interest.                   */
	poVRTBand->SetMetadata( poSrcBand->GetMetadata() );
	poVRTBand->SetColorTable( poSrcBand->GetColorTable() );
	poVRTBand->SetColorInterpretation(poSrcBand->GetColorInterpretation());
	if( strlen(poSrcBand->GetDescription()) > 0 )
		poVRTBand->SetDescription( poSrcBand->GetDescription() );
	dfNoData = poSrcBand->GetNoDataValue( &bSuccess );
	if ( bSuccess )
		poVRTBand->SetNoDataValue( dfNoData );
	return CE_None;
/*                           CopyRasterWindow()                         */
/*      Return a virtual dataset representing the specified pixel       */
/*      window of the source dataset.                                   */
	VRTDataset *poVDS = NULL;
    int nBandCount = 0, i;
    double adfGeoTransform[6];
    const char *pszProjection;
    char **papszMetadataOptions = NULL;
	poVDS = new VRTDataset( nSrcXSize, nSrcYSize );
	pszProjection = GDALGetProjectionRef( hSrcDS );
	if( pszProjection != NULL && strlen(pszProjection) > 0 )
		poVDS->SetProjection( pszProjection );
	if( GDALGetGeoTransform( hSrcDS, adfGeoTransform ) == CE_None)
			adfGeoTransform[0] += nSrcXOff * adfGeoTransform[1]
				+ nSrcYOff * adfGeoTransform[2];
			adfGeoTransform[3] += nSrcXOff * adfGeoTransform[4]
				+ nSrcYOff * adfGeoTransform[5];
			poVDS->SetGeoTransform( adfGeoTransform );
	else if( GDALGetGCPCount( hSrcDS ) > 0 )
			GDAL_GCP *pasGCPs;
			int       nGCPs = GDALGetGCPCount( hSrcDS );
			pasGCPs = GDALDuplicateGCPs( nGCPs, GDALGetGCPs( hSrcDS ) );
			for( i = 0; i < nGCPs; i++ )
					pasGCPs[i].dfGCPPixel -= nSrcXOff;
					pasGCPs[i].dfGCPLine  -= nSrcYOff;
			poVDS->SetGCPs( nGCPs, pasGCPs,
							GDALGetGCPProjection( hSrcDS ) );
			GDALDeinitGCPs( nGCPs, pasGCPs );
			CPLFree( pasGCPs );
	poVDS->SetMetadata( ((GDALDataset*)hSrcDS)->GetMetadata() );
	AttachMetadata( (GDALDatasetH) poVDS, papszMetadataOptions );
	nBandCount = GDALGetRasterCount( hSrcDS );
	for( i = 1; i <= nBandCount; i++ )
			CopyRasterBand((GDALDataset *) hSrcDS, poVDS, i, nSrcXOff, nSrcYOff, nSrcXSize, nSrcYSize);
	return poVDS;
/*                           SplitFile()                                */
/*      Split the specified file into the required number of tiles.     */
static int SplitFile(const char * pszSource, int cols, int rows, int bQuiet, GDALProgressFunc pfnProgress)
    GDALDatasetH hDataset, hOutDS;
    VRTDataset *poVDS;
    int i,x,z;
    int nRasterXSize, nRasterYSize,
		nSrcXOff = 0, nSrcYOff = 0,
		nRoundedXSize, nRoundedYSize,
		nSrcXSize = 0, nSrcYSize = 0;
    GDALDriverH	hDriver;
	char * pszDest;
/*      Attempt to open source file.                                    */
    hDataset = GDALOpen( pszSource, GA_ReadOnly );
    if( hDataset == NULL )
			fprintf( stderr,
					 "GDALOpen failed - %d\n%s\n",
					 CPLGetLastErrorNo(), CPLGetLastErrorMsg() );
			return ( 0 );
    if( CSLCount(GDALGetMetadata( hDataset, "SUBDATASETS" )) > 0 )
			fprintf( stderr,
					 "Input file contains subdatasets. Please, select one of them for reading.\n" );
			GDALClose( hDataset );
			return ( 0 );
    nRasterXSize = GDALGetRasterXSize( hDataset );
    nRasterYSize = GDALGetRasterYSize( hDataset );
    if( cols > nRasterXSize )
			fprintf( stderr,
					 "The column count cannot be greater than the image width in pixels.\n" );
			return ( 0 );
    if( rows > nRasterYSize )
			fprintf( stderr,
					 "The row count cannot be greater than the image height in pixels.\n" );
			return ( 0 );
	if( !bQuiet )
		printf( "Splitting %s size %d, %d into %d files...\n"
				, pszSource, nRasterXSize, nRasterYSize, cols * rows);
/*      Find the output driver.                                         */
	hDriver = GDALGetDatasetDriver( hDataset );
/*      Establish some parameters.                                      */
	nRoundedXSize = (int) round(nRasterXSize / (double) cols);
	nRoundedYSize = (int) round(nRasterYSize / (double) rows);
/*      Make a virtual clone.                                           */
	for (i = 1, z = 1, nSrcXOff = 0; i <= cols; i++, nSrcXOff += nSrcXSize) {
		nSrcXSize = (i != cols) ? nRoundedXSize : nRasterXSize - nRoundedXSize;
		for (x = 1, nSrcYOff = 0; x <= rows; x++, z++, nSrcYOff += nSrcYSize) {
			pszDest = CreateFileName(pszSource, i, x);
			if (!pszDest)
				return FALSE;
			nSrcYSize = (x != rows) ? nRoundedYSize : nRasterYSize - nRoundedYSize;
			if (!bQuiet)
				printf("%d. %s size is %d, %d\n  ", z, pszDest, nSrcXSize, nSrcYSize);
			poVDS = CopyRasterWindow(hDataset, nSrcXOff, nSrcYOff, nSrcXSize, nSrcYSize);
/*      Write to the output file using CopyCreate().                    */
			hOutDS = GDALCreateCopy( hDriver, pszDest, (GDALDatasetH) poVDS,
									 TRUE, NULL,
									 pfnProgress, NULL );
			if ( hOutDS != NULL )
					GDALClose( hOutDS );
			GDALClose( (GDALDatasetH) poVDS );
			free(pszDest);
    return ( hOutDS != NULL );
/*                           CreateString()                             */
/*      Takes printf() arguments and formats output to appropriately    */
/*      allocated string.                                               */
/*      The code is adapted from that found in the glibc vsnprintf      */
/*      man page.                                                       */
/*      It is up to the caller to free the result.                      */
static char * CreateString(const char *fmt, ...) {
	/* Guess we need no more than 100 bytes. */
	int n, size = 100;
	char *p;
	va_list ap;
	if ((p = (char *) malloc (size)) == NULL)
		return NULL;
	while (1) {
		/* Try to print in the allocated space. */
		va_start(ap, fmt);
		n = vsnprintf (p, size, fmt, ap);
		va_end(ap);
		/* If that worked, return the string. */
		if (n > -1 && n < size)
			return p;
		/* Else try again with more space. */
		if (n > -1)    /* glibc 2.1 */
			size = n+1; /* precisely what is needed */
		else           /* glibc 2.0 */
			size *= 2;  /* twice the old size */
		if ((p = (char *) realloc (p, size)) == NULL)
			return NULL;
/*                           CreateFileName()                           */
/*      Create filename based on source filename but specifying         */
/*		required column and row.                                        */
	char *basename = GetBasename(pszSource);
	char *dirname = GetDirname(pszSource);
	char *ext = GetExtension(basename);
	char *filename;
	if (ext) {
		basename[(strlen(basename) - strlen(ext))-1] = '\0';
		filename = CreateString("%s%c%s_c%d_r%d.%s", dirname, PATH_SEP_CHAR, basename, col, row, ext);
	} else {
		filename = CreateString("%s%c%s_c%d_r%d", dirname, PATH_SEP_CHAR, basename, col, row);
	free(dirname);
	free(basename);
	free(ext);
	return filename;
/*                           GetExtension()                             */
/*      Return the extension portion of a filename or NULL if none      */
/*		is present.                                                     */
	char *ext;
	char *p = rindex(basename, '.');
	if (!p)
		return NULL;
	if (p < rindex(basename, PATH_SEP_CHAR))
		return NULL;
	if ((ext = (char *) malloc (strlen(p))) == NULL) /* no need to do strlen(p + 1) because we are going to disregard the '.' */
		return NULL;
	strcpy(ext, ++p);
	return ext;
/*                           GetDirname()                               */
/*      Return the directory portion of a filename or '.' if none       */
/*		is present.                                                     */
/*      Code adapted from bash dirname command.                         */
	int slen;
	char * psTmp;
	char *dirname;
	slen = strlen (string);
	/* Strip trailing slashes */
	while (slen > 0 && string[slen - 1] == PATH_SEP_CHAR)
		slen--;
	/* (2) If string consists entirely of slash characters, string shall be
	   set to a single slash character.  In this case, skip steps (3)
	   through (8). */
	if (slen == 0)
		return CreateString("%c", PATH_SEP_CHAR);
	if ((psTmp = (char *) malloc (slen+1)) == NULL)
		return NULL;
	strcpy(psTmp, string);
	/* (3) If there are any trailing slash characters in string, they
	   shall be removed. */
	psTmp[slen] = '\0';
	/* (4) If there are no slash characters remaining in string, string
	   shall be set to a single period character.  In this case, skip
	   steps (5) through (8).
	   (5) If there are any trailing nonslash characters in string,
	   they shall be removed. */
	while (--slen >= 0)
		if (psTmp[slen] == PATH_SEP_CHAR)
			break;
	if (slen < 0)
			free(psTmp);
			return CreateString(".");
	/* (7) If there are any trailing slash characters in string, they
	while (--slen >= 0)
		if (psTmp[slen] != PATH_SEP_CHAR)
			break;
	psTmp[++slen] = '\0';
	/* (8) If the remaining string is empty, string shall be set to a single
	   slash character. */
	if (slen == 0)
		dirname = CreateString("%c", PATH_SEP_CHAR);
	else
		dirname = CreateString("%s", psTmp);
	free(psTmp);
	return dirname;
/*                           GetBasename()                              */
/*      Return the basename of a filename, including extension.         */
/*      Code adapted from bash basename command.                        */
	int slen;
	char *psTmp, *psTmp2, *psTmp3;
		slen--;
	   through (5). */
	if (slen == 0)
		return NULL;
	psTmp[slen] = '\0';
	/* (4) If there are any slash characters remaining in string, the prefix
	   of string up to an including the last slash character in string
	while (--slen >= 0)
			break;
	if (slen == 0)
		return psTmp;
	for (psTmp2 = &psTmp[slen+1], psTmp3 = psTmp; *psTmp2 != '\0'; psTmp2++, psTmp3++)
		*psTmp3 = *psTmp2;
	*(psTmp3++) = '\0';
	return psTmp;
.TH "gdalsplit" 1 "14 Sept 2004" "gdalsplit" \" -*- nroff -*-
.ad l
.nh
.SH NAME
gdalsplit \- splits raster datasource(s) into tiles
.SH "SYNOPSIS"
.PP
.PP
.PP
.nf
       [-c cols]
       [-r rows]
       [-quiet]
       src_dataset...
.PP
.SH "DESCRIPTION"
.PP
is, for instance, useful in conjunction with the \fBgdaltindex\fP
program. The output files are created in the same directory as the
source files. The source dataset is not deleted.
.PP
unless the columns and rows specified exactly divide into the source
dataset width and height respectively.
.PP
.IP "\fB\fB-c\fP cols\fP:\fP" 1c
Select the number of columns \fBcols\fP to split the source dataset into. The default is 2.
.IP "\fB\fB-r\fP rows\fP:\fP" 1c
Select the number of rows \fBrows\fP to split the source dataset into. The default is 2.
.IP "\fB\fB-quiet\fP:\fP" 1c
.IP "\fB\fIsrc_dataset\fP:\fP" 1c
.PP
.SH "EXAMPLE"
.PP
.PP
.PP
.nf
.PP
.nf
utm_c1_r1.tif
utm_c1_r2.tif
utm_c1_r3.tif
utm_c2_r1.tif
utm_c2_r2.tif
utm_c2_r3.tif
utm_c3_r1.tif
utm_c3_r2.tif
utm_c3_r3.tif
.PP
.SH "AUTHORS"
.PP
Homme Zwaagstra <geodata at soton.ac.uk>
